Attn Vulcan performance
Old 02-09-2009 | 04:40 PM
lvmknsmoke..'s Avatar
i stil wanna check some more codes but i do believe its time for a new vp. i had dead pedal this morn and this is not the first time its happend. ok thing is i also want a fass to go with it.. just lookin to go with the pump. my ? is wats the difference between the ddrp pump and and the hpfp?? i see u offer both in package deals along with the vp? just curious?
Old 02-09-2009 | 07:06 PM
anyone else can add there 2cnents im just curious wat the difference is? is the ddrp just some kind of replacement on the vp44? i want a lift pump.. i dont need whole system with filters and al just want pump..
Old 02-09-2009 | 07:48 PM
MSquare's Avatar
The DDRP is a direct replacement lift pump that mounts in the factory (side of block) location.
I believe the HPFP mounts on the frame in the same location as the "full meal deal" FASS system.
Old 02-09-2009 | 08:37 PM
is there a difference in the two? or are u sayin ddrp takes place of stock lp and u stil need a hpfp?
Old 02-09-2009 | 09:32 PM
hink's Avatar
The DDRP is made to be a direct replacement for the stock lift pump.....BUT, it can also be mounted on the frame rail and used as a pusher pump, you would then remove the stock engine mounted LP. I believe that the DDRP comes as a pump only, if you want to mount it on the frame rail, then you have to order the parts in addition to do so.
The HPFP pump comes with everything to mount it on the frame rail and plumb it to the VP44 and wire it up. It will also bypass the stock pump.
As far as specs between the 2 pumps, I don't not know the differences between the 2.
Old 02-09-2009 | 11:15 PM
Russ Roth's Avatar
I doubt Eric will see this. Probably best to call.
JARHEAD
03-20-2008 09:37 PM
Dinner
02-13-2008 05:40 PM
pull-do
08-08-2007 12:13 AM
Soffitguy
07-06-2007 12:21 AM
NavyChief
17
08-23-2005 06:40 PM
