Attitude monitor not working...HELP!!!
Just installed a USED Edge Juice w/ Attitude that I bought from a friend of mine. I did not hook up the Turbo Timer, Trans Temp or tap the VP44. Everything else is connected.
Turned the key to the "ON" position......Nothing.
Switched the power wire from the SPARE 15 amp slot to the Quad Light 15 amp slot and still NOTHING
I took the plate off the edge module and there were no "diagnostic lights" on in the end of the module when the truck was running.
Anyone have any ideas??
Similar thing happened to me and it turned out to be the wire that gets jammed in there with the fuse came out, not the one under the hood but the one to the left of the steering wheel, hope that's what it is for you, simple fix! Good luck.
The diagnostic lights only work once you tap the Wire to the pump. at least thats what I read in the manual...mind you I instlled mine last friday. are you going to hook up the EGT/tranny? oh and tap the VP?
I did the same thing, hooked up the J/A without the turbo timer and got the same results as you. Called Edge and they said that on my year model hooking up the turbo timer was required for the J/A to work. Fixed the problem. In regards to the diagnostic lights, mine work fine without tapping the VP44.
Sleigher
05-04-2017 03:12 PM
Price_Dog
18
10-14-2008 10:54 PM
nitis
02-26-2007 08:38 PM
Igor
10-25-2005 04:57 PM
LIAC
08-10-2005 11:37 AM
