Att. Vulcan Performance, Gauge pack. 1
Old 03-31-2009 | 04:28 PM
lvmknsmoke..'s Avatar
i bought your isspro gauge package 1. and i just had the gauges installed and the guy said for the fuel press. line that its not long enough and that it also was loose at the connection fittings.. just wonderin if he is wrong or wat.. thanks
Old 03-31-2009 | 06:33 PM
Dinner's Avatar
If you wanted you could go and buy a 1/8th'' compression fitting joiner, this will allow you to hook two lines together. I'm not quite sure what you mean by loose at the connection fittings, loose on the gauge itself?
Old 03-31-2009 | 07:35 PM
Fishin2Deep4U's Avatar
Might be easier to give us a call at the shop so that it can be handled directly, but I have not heard of either of these issues in the past. And of course we always stand behind these products, so if there is an issue, a phone call can get it handled fast.
Which fuel pressure line? I will assume the rubber line from the injection pump to the isolator. That line is the same length in every kit and easily allows placement of the isolator virtually anywhere on the firewall. In fact, most guys say there could be less line. But it has to fit all applications. If we are talking about the nylon tubing the glycol goes in, there is enough to run the gauge to the glove compartment. So, I am not sure what he's talking about.
Regarding loose fittings, none of the fittings are installed for final fit. This must be done by the installer and the sealer that is included must be used to prevent leaks on the pipe threads.
Dave
tauberson
05-02-2008 09:59 AM
Joe T
16
06-12-2007 01:11 AM
ocsurf16
10-04-2006 11:19 PM
NavyChief
17
08-23-2005 06:40 PM
