ATS trans pan
The Guru
I just installed an AFE deep pan yesterday. Yes you need the spacer and follow the directions, as my spacer required an o-ring to mount up to the valve body. So far I don't have any leaks yet.
Remember to buy an extra 4-5 quarts of fluid. You running ATF or ATF+?
I have 01 so not sure which fluid is in there. I also have TransGo shift kit so hopefully Ill have shop put that on in spring, along with deep pan.
mar67655
03-14-2009 07:22 PM
MrKen
11-23-2006 03:19 PM
bostongsx
09-25-2006 11:25 PM
