ats intake horn
Old 04-14-2005 | 01:26 PM
halerazor's Avatar
ats intake horn
http://www.atsdiesel.com/products/pr...ine-intake.asp
has anyone seen this or used it. hopefully it flows better than banks horn ecspecially for $350 and wonder if it makes a difference
Old 04-14-2005 | 03:25 PM
HOHN's Avatar
Looking at the intake surface on the head will tell you that an aftermarket intake horn, even if perfectly designed, can do very little to improve airflow to the engine.
It's a solution to a problem that doesn't exist-- at least to any significant degree.
jlh
Old 04-15-2005 | 12:22 AM
halerazor's Avatar
thats alot of money for a slight increase in power
Old 04-15-2005 | 08:08 AM
mikelr's Avatar
You could probably get more performance from removing the grid heater than from that ATS intake.
Old 04-15-2005 | 09:42 AM
penning10's Avatar
The ATS horn is the better value as it comes with several benefits. First of all you get the minor increase in air flow including less work on your turbo to the intake. Second, the ATS has all pre-drilled mounting points for nitrous/propane/water injection for a straight and efficent shot of juice. If you do your research on this, it allows for so much more than the Banks, and is very versatile for mods.
Old 04-15-2005 | 10:24 AM
BigBlue's Avatar
Only benefit that I could see with it is the pre drilled mounting bosses. But even then, if you can use a drill, you can tap it yourself. Sorry. Not worth the money IMO.
dieselcarpenter
03-26-2008 06:08 PM
mpminc
05-12-2007 12:02 PM
natlchamp2k4
03-13-2007 06:47 AM
Bobcat698
09-24-2005 11:51 AM
Lightman
03-03-2005 01:41 PM
