anything else I should do, tranny swap?
Old 01-04-2008 | 10:33 PM
LanceD's Avatar
I am going to be putting a Goerend transmission in soon and im wondering if there is anything else I should do while I have the transmission out? I was thinking about changing the rear main seal if its easy? what else?
Old 01-05-2008 | 08:17 AM
olddodgetruck's Avatar
i see that you wheel you truck alot, maybe a tranny cooler with a fan. how hot does you tranny get now offroading
Old 01-05-2008 | 09:28 AM
JD730's Avatar
How many miles on this truck? Less than 100k I would leave the rear main alone. Over 150k I would probably change it.
Old 01-05-2008 | 03:35 PM
haloman's Avatar
Ujoints, T-case gaskets
Old 01-05-2008 | 06:22 PM
LanceD's Avatar
it has 160k. it doesn't leak from the rear gasket, but the Tcase leaves a trail. wheres the best place to get a gasket kit for the 241? is the rear main seal easy to change?
what about the chain inside the transfer case? I should probably change that too.
the only time I see my trans temp go up is while offroading, I think I got it up to 220 once when I was trying to get unstuck.
Old 01-05-2008 | 07:46 PM
xtoyz17's Avatar
www.makeitmopar.com
...and you really shouldn't have to do anything to your transfercase.
Old 01-05-2008 | 07:53 PM
oldblues's Avatar
hi
most likely transfer case leak is realy the rear seal in the trany , easy to change when case is removed .
does the fluid level drop in the trany or the tranffer case ?
Old 01-05-2008 | 07:58 PM
LanceD's Avatar
it doesn't leak bad enough to notice a drop in either one.
Old 02-06-2008 | 06:28 AM
LanceD's Avatar
back to the top, I got a t-case saver and new seals to put in. the chiltons book I have says to not re-use the nut for the flange that the front driveshaft bolts to, is this true?
anyone know where I can find detailed instructions for removal and installation of a transmission, and rebuilding a NP241?
im pretty sure I can do it without, but want to make sure im not missing anything.
going to buy a new rear main seal also.
I Stand Alone
01-26-2012 09:41 AM
Cowboy_Customs
04-06-2006 06:43 PM
Syndicate
02-21-2006 07:34 PM
Dodgezilla
10-26-2004 12:28 AM
RonP
10-15-2004 07:52 PM
