anyone who has a raptor 150 please look
Old 10-30-2009 | 07:27 PM
realtreehunter's Avatar
before i order the raptor 150 i was just wondering if you also needed to order a new straw to go along with it or anything like this.. i just want to order everything at once.. thanks
Old 10-30-2009 | 07:52 PM
OldDodgeOwner's Avatar
I didn't install a draw straw with mine. Just hooked it up straight to the factory pickup with the supplied quick-connect. I think the drawstraw is only required if you have the in-tank lift pump. I bought a draw straw, but didn't use it. The pump seems to pull plenty of fuel through the factory pickup. Only thing I might recommend is to get a big-line kit from the filter housing to the injection pump as well. The Raptor kit comes with everything else needed.
Old 10-30-2009 | 10:28 PM
Awesome thanks.. And if I end up needing a straw ill be PMing you lol
Old 10-31-2009 | 02:16 AM
Not a problem, I've got the straw sittin here if you need one, but I doubt you will
Old 11-01-2009 | 08:05 PM
MATTIEBOB's Avatar
i ran a straw on mine but when i bought mine the 150 required it. it even came with the pump. i did call the guys at pureflow and they said it might not need a straw unless my truck had an in tank pump. i installed the straw anyway to be safe, but i heard of a lot of guys not using the straw.
White97GTVert
13
04-21-2011 09:51 PM
zchornyak
13
04-14-2008 03:28 PM
VaultRam
40
04-10-2008 10:45 PM
goose2w1
02-29-2008 09:45 AM
84mphcdt
16
12-19-2007 12:31 PM
