Anyone try the $29.95 Fuel plate on Ebay?
Old 02-22-2009, 01:49 PM
  #31
rebel5422's Avatar
if ur talking about the peice im thinking of its so ucan put the new plate in the same place as the old plate when u pull ur afc housing off u put that piece on and bolt it down next to ur old plate and when u pull ur old plate off u can set the new one in the same place just line it up with the metal piece u bolted down but in my opinion u dont need it just slide it all teh way forward unless u tow alot then i think everyone will tell u to put it in the stock pos or just slightly forward i guess its really up to u and how u drive and if u tow alot as to where u put it the afc housing and the star wheel
Old 02-22-2009, 05:37 PM
  #32
JohnBer's Avatar
Originally Posted by Wicked500R
Waiting on results.. I didn't get mine in yet
i installed mine where the stock plate was. used the guide. AFC all the way forward. pyro runs up to about 1250 if i hit it hard and stay in it. best boost i saw was 32 psi. I'm impressed. works great, sure woke the truck up . of course this is flat land running empty on a 35*F day.
Old 02-22-2009, 05:39 PM
  #33
Wicked500R's Avatar
Full forward should be interesting !
Old 02-22-2009, 05:52 PM
  #34
JohnBer's Avatar
might wanna try it in stock position first. it only took me 40 minutes to put it in and it was my first try at it. be quicker now the break off bolt is replaced.
Old 04-12-2009, 10:41 PM
  #35
p.o.s.'s Avatar
just oredered mine off ebay for $30.00 howd everyone else do with theres i have a complete stock set up will I run into any problem with this kit?
Old 04-13-2009, 12:20 AM
  #36
wcbcruzer's Avatar
Once you get the breakoff screw replaced you don't even have to take off the intake horn the next time.
Old 04-13-2009, 01:34 AM
  #37
Dr. Evil's Avatar
You need to have a pyrometer as a minimum...do you have one?
Old 04-13-2009, 11:58 AM
  #38
p.o.s.'s Avatar
ill be gettin the pillar mounted egt, boost, and fpr gauges before installing the fuel plate.....
Old 04-13-2009, 03:43 PM
  #39
DTR's Toad Wrangler
Clayten's Avatar
You can change the boost and performance by adjusting the gov. arm up or down.
duallydave
33
07-12-2007 10:48 PM
Mr. Jimmy
02-09-2006 02:26 PM
MNorby
18
09-03-2005 03:19 AM
Badd Dogg Guy19
07-30-2005 07:07 PM
Quick Reply: Anyone try the $29.95 Fuel plate on Ebay?
