anyone running a TAD B1
Old 03-27-2006 | 10:50 AM
getblown5.9's Avatar
the full on B1 from TAD, trying to gain as much info about it as possible...
compressor size, housing size, wastegated?????? which DP does it use, how well does it spool etc? i cant find any info by searching, most threads were pertaining to common rail 3rd gen trucks using this turbo
Old 03-27-2006 | 11:10 AM
RowJ's Avatar
Uses a Custom B-1 Downpipe. Full B-1 will spool as slow or slower than your Lil 55/16, IMO.
Based on my expirience with a KSB-1 (same compressor).... B-1's are a lot easier to bark and have a lot higher pitched turbo whine. Much more in-cab noise!
RJ
Old 03-27-2006 | 11:19 AM
gotcha...thats what i was afraid of!
gotta keep looking for another alternative
Old 03-27-2006 | 11:33 AM
Willy91's Avatar
I'm running a full B-1 with my mods and it spools pretty good. Maybe the B-1-2 would work good for you. It spools up a lot better than the full B-1, but it won't support as much top end power.
Old 03-27-2006 | 11:35 AM
*****...being a 12v i really dont understand exactly how much fuel/power you are running, i just know that you have ALOT
im running 150hp sticks, and a standard 120hp edge comp...
Old 03-27-2006 | 11:54 AM
Willy91's Avatar
Last dyno run was right at 456HP. I didn't really understand how much power you were running either I was just making a suggestion.
Old 03-27-2006 | 12:06 PM
RowJ's Avatar
One other fact I dug out of my bookmarked threads.....
B-1 move about 950 cfm cool air
HX-55 moves 1050 cfm. (this may be the standard HX-55, with the 66mm Compressor bore, and not the lil 55 with a 64 mm)
Either way I don't see the Full B-1 as a step up from the Lil-55. Both move a lot of air and are a big step up from HX-35 or HX-40. Both have upgraded oiling system, zero balancing, high flow housings and stronger shafts. Just don't think it's the upgrade your looking for.
RJ
RJ
Old 03-27-2006 | 12:29 PM
RJ im looking to downgrade one step from the lil 55. i need something with a 12 or 14 cm housing that still moves lots more air than stock...but this 55 is not a good street mannered turbo with the 16cm housing. i wanna go one step smaller for better spool up even if it does mean i lose 100cfm on the top. egt's are well under control now, and were controllable with my right foot on the hx35/14 i had before, so soemwhere in between will leave me with a drivable set-up, and egts that are pretty much under control unless i wanna try to break a land speed record
Old 03-27-2006 | 07:24 PM
Jetpilot's Avatar
getblown5.9,
Give me a call and I would be happy to explain all the differences in the different turbos.....
Doug Smith
Old 03-27-2006 | 07:34 PM
doug i spoke to ya on friday and was all set to go with a HTB2 but that deal kinda fell thru. so im trying to explore my other options
Tim
Old 03-27-2006 | 09:03 PM
JTrantham's Avatar
It seems kind of "obvious," but why not just slap a smaller housing on your lil'55? If it need be, you can have the exhaust housing machined larger to(to fit you turbine wheel). I would just talk to J.R. about getting a smaller housing. My 17 cm housing had to be machined out to fit over my exhaust wheel, but it is much larger than the lil' 55 wheel.
Jonathan
Old 03-28-2006 | 12:16 AM
because its $700 for a 14cm housing for the 55, as quoted to me by JR...id rather swap them out for an even trade or even trade plus $100-200 but im not gonna put another $700 into a used turbo when i can send it to someone who can use its bigger size and ill get something smaller
mitchgmace
01-14-2007 08:07 PM
98Ram25004x4
07-03-2006 03:14 PM
Bobcat698
04-22-2005 01:40 PM
kd460
01-23-2005 06:49 PM
