Anyone running a Powermax 3 w / stock turbo
I'm about to pull the trigger on a Powermax 3 to stack
with my Smarty and RV275 injectors. Going to keep the
stock turbo. Anyone have experience with this setup ?
How high of a level can I go to for shrt blasts. Powermax
will be turned off when towing
Im running the PM3 Comp/Smarty with 95hp injectors on my stock turbo. And when just doing some playing around in town its fine, but if I try to do a 1/4 mile drag it gets to 1600 deg. quick! I tow with the smarty on 3 and the TST on 4 or so and its fine as long as Im on level ground. Im about to get some more air for this thing and I think it should help alot.
I did for a while with my dd2's and stacked with an ez. Oh yeah.. that was with the hy-9 . I could hit 40lbs of boost in about half a second!!! She held pretty well but above 2500 rpms the temps were out of control on level 3. I had no problem breaking 35's loose on dry pavement in first and second gear though.
So from what everyone is saying , if I get
the Powermax 3 , even though it has 9 levels
I'll only be able to use level 3 or 4 ? Maybe I
should get the Powermax 2 which is equal to
level 6 , but without the adjustable remote and
save $150.00
save $150.00
I just installed a TST PM3 comp., with smarty and stock turbo. Put smarty on 5 and TST on 2. Half throttle, and my dad and I are lookin at each other like 'holy *&$#'. Huge difference, I didnt try any higher levels, but EGT's got to about 1100 pretty quick, I'm sure it could top 1400 easy. Also, I installed the boost elbow, but 22 psi was the highest I saw, wonderin if I should see more boost.
You should be able to run it on level 9. It will get HOT and quick. I ran a tst, power puck, and 90+hp injectors on the stock turbo for a long time. I usually drove with the TST off and turned it on when needed.
Beeram you should be seeing about 35 PSI. Check for boost leaks.
Go for it.
Doug
If you bought a campain pump and a vulcan kit you could be done for less than $200, or a little more with the draw straw.
But why spend all that money and leave the turbo stock??
Seriously though- how's that boost controller set up? I thought they were meant to help with lag and from the looks of it- you should have no lag
Moobesor
05-09-2008 05:59 PM
dodgediesel
54
03-17-2007 08:40 AM
dodgediesel
17
11-18-2006 12:47 AM
red12valve
08-22-2006 02:35 PM
VIPERBLUELX
08-05-2006 05:22 PM
