Anyone running a Helix cam
At 450 rwhp my 01 H.O. is running pretty warm egts with comp box in upper levels i was wondering how the helix 1 and 2 cams would do for reduceing egts. I would like to be able to run with box on kill and be ok , im running a htb2 62/12 at 42psi. Also the manual fuel pump would be perfect.
The best thing I found after having a Helix 2 cam installed was how much better trottle response became. Improved fuel economy and helping the turbo get going is the main reason I bought one.
Todd
Todd
If I can answer any more questions please feel free to phone.
Doug
717-557-7060
DTR Advertiser
With the helix 2 do you have to change valvetrain? Thanks for the replys.
Anyone wanting to twist over 3200 RPM and over 45 PSI should have the springs. Even the stock springs and cam can begin valve float at these levels. Back pressure level plays a part as well.
Yes, you can change out that goofy electric pump and use a mech pump. A complete kit is available at a very competitive price when you compare the cost of the aftermarket electrics.
Don~
Olee Poole
68
07-10-2007 05:38 PM
Gabe32
03-21-2007 07:22 PM
06dmc
13
10-09-2006 11:25 AM
Timinva
18
12-07-2005 05:06 PM
