Anyone Make Shocks For A 2WD With A Two Inch Lift?
Chirs
so you ran the stock length blistiens with the 2 inch lift and couldnt tell a difference from the skyjackers +2?
If thats the case Ill just run bilstien HDs
I honestly don't know if there is enough stroke in a stock shock to be used on a 2" lift.
I CAN tell you that at 2.5" lift, the upper control arm will hit the bump stop mount and make a lot of noise when the suspension unloads. Never go any higher than 2" lift on a 2wd
Chris
Jordan5687
02-18-2009 02:48 PM
KKoteles
30
04-16-2008 11:07 PM
EverydayDiesel
0
11-18-2007 11:23 PM
EverydayDiesel
08-19-2007 09:38 AM
KKoteles
06-19-2007 06:06 PM
