anyone know of a....
lift kit for a 2nd gen (1999) 2wd suspension.
i have looked all over....skyjacker, fabtech, RCD...no one lists one.
i am looking to be able to fit 33's on 16/17's....i see there is a 1,1.5,2" front end leveling kit by some company i have never heard of...daystar i believe.
any feed back is appericated.
NCA
NCA
The Daystar spacers are a good product, I have never personally used them but have hear much good, and no bad about them... If you don't want a level truck you could use an ad a leaf, or taller rear block. Or have the rear springs re arched...
NCA
ps does anyone know the tire heights...ie...what does a 285,305,315 equal to i heard a 315 is equall to a 33" tire...any truth to that
the 315, is the width in MM... the height will depend on the rim size, and that 2nd #, which (if I remember correctly) would be the height in relation to the width in percentage. for example, a 315/75-16... 315 is your width, 75% of that width is the hight of the sidewall and a 16" rim. Someone crrect me if I got it wrong... it's been 12 years since I worked in a tire shop, and that was just wal-mart... and you know what that's like LOL! I was probably told wrong way back then. HAHA!
You will not get a 2wd up as high as a 4x4 , at least not without some big time expensive custom fabricated stuff.
the stock control arms limit you to about 2" of lift in the front ( a leveling kit) , and no aftermarket control arms are available.
A 285 75 16 is a 33" tire (roughly) and a 315 75 16 is a 35" tire (roughly) with that said , my 285's are as tall , but not as wide as some 315's i have parked beside.
how do you mean "not as high as a 4wd" i know i cant equall a 4wd with lift but how about stock or a little better???
with that said....would it be fair to say...with the 2" leveling kit in front and 285's all around...i would be in the ball park of a stock 4wd...hmmmmm
NCA
morkable
ABDTR #5
16
09-10-2009 11:41 PM
jeffs07mega
02-24-2009 02:47 AM
