anyone installed autometer electric f/p gauge
Dakota Digital
Jerry B4;
I've had my Dakota Digital fuel pressure gauge inservice fro about 2 years or better with no problems. The supplied VDO sender is attached to the VP-44 via a 18" grease gun hose.
In fact, the Dakota helped me get a repalcement lift pump form the dealer under warranty.
JC
JC
Originally posted by xj_punk
so that will work with the banjo bolt i ordered from dieselinnovations?
that is sweet and only 19 bucks, i'm ordering it.
where did you mount your sender?
Originally posted by NOSPIN4ME
You will not need the banjo bolt with this hose. As far as mounting the sender, I used a tie wrap to hold it in place on the inner fender. The hose will absorb any vibrations from the motor.
so you don't need the banjo bolt, because the hose replaces it? i am sure i can make this thing work.
This is how I installed my shut-off valve...
Fuel shut off valve mount
I bought an angle brace from Home Depot and screwed it to the inside of my fender..
Can you use a mechanical gauge off the VP service port? And just use either an isolater or check valve, and just use it with that hose? Just screw the needle valve into the hose?
FP Gauge
XJ;
I don't have a digital camera but I replaced all my banjos iwth Thorsen oversized banjo bolts. I bought one tapped which I installed on the VP-44 test port. The grease gun hose screws right in the tapped banjo. Use petrol resistant teflon tape. The pressure sender screwsa to the other end. I wire tied it to the power steering hoses.
Follw install instructions for the gauge you purchase.
ACJC
ACJC
Hillbilly_Deluxe
10-26-2007 09:48 AM
RoadDiesel
05-30-2007 10:39 PM
rjm022
05-04-2007 08:29 PM
rjm022
07-09-2006 04:15 PM
rjm022
15
02-03-2006 09:35 AM
