anyone installed autometer electric f/p gauge
or any electric f/p gauge. just curious to know how to set it up. i bought one today.
a write up would be kind of nice!
here is a link to the instructions, but they are super general
http://hp.autometer.com/instructions...nstruction.pdf
thanks for any help you can provide
i got the cobalt, it goes to 30psi, its cool looking.
I'd suggest mounting the sending unit up on the firewall or someplace other than the engine. My first one was shaken, not stirred, to death. Moved it up on the firewall over two years ago and have not had any problem with it since. One important item is your ground, make sure you have a good one.
Casey
Casey
mine was too simple. It's inline on my vulcan kit, used the adapter included w/ the kit. But, the sender should thread into your fuel filter box, in the test ports.
When it came to routing the wires through the firewall I cut them and used the same grommet and for the pyro and boost. It became a tight fit, but it works like a charm. To fit the sender you'd have to drill something like a 1/2" hole. I couldn't find a spot to drill a hole that large, easily. So, I got lazy and shoved the pyro, boost and fp gauge all through the boost grommet.
Re: anyone installed autometer electric f/p gauge
http://dieselinnovations.com/index.htm
I hope this helps, Tye.
Re: Re: anyone installed autometer electric f/p gauge
so do i have to take the cover off the vp44? do you know of any detailed instructions for this install. i have never installed a f/p gauge and i am not sure what to do.
is the different banjo bolt required?
thanks for your help
-nate
-nate
Originally posted by BUCKSHOTMCKEE
I'm running the Z-series 0-30 electric fuel pressure gauge. I removed the service/test port on the Vp44 and bought a bigger banjo bolt with a open threaded end to put the sending unit into. It was quite simple install. Then the harness just plugs in once the sender is installed into the banjo. Here is were I got the Banjo bolt.
Re: Re: Re: anyone installed autometer electric f/p gauge
-nate
-nate
Tye
xj_punk,
The old style Auto Meter FP gauegs were not really set up for the Dodge, they used ot have only a 0-15 PSI and the operation was a little shall we say weak! They have recognized the need to be "IN" the diesel market and the current 0-30 or 0-100 PSI FP systems are really pretty bullett proof, we have been selling them for over a year now with 0 problems. It is approx 50.00 more than a mechanical gauge with an isolator and hose kits, but you have almost 0 worries for leask, just the sending unit, and the install is LOTS easier. They currently have FP gauges in the Z , Ultra Lite, Phantom, Sprot Comp,Cobalt, C2 and Nexus styles. Call us if you have any questions etc.
Mark @ DPPI
Mark @ DPPI
do you want to tell me how to install it? hehe
should i go to the post filter test port on top of the canister or to the pump?
Originally posted by Mark Craig
xj_punk,
Mark @ DPPI
xj_punk,
Mark @ DPPI
just talked to dieselinnovations and ordered the banjo set.
i think i want to get some more fittings and mount it solid to like the fender or something, but that would require making a custom hose/line.
what do you guys think? they say in the instructions that vibration can ruin senders.
Something took mine out twice before I switched...should be easy enough to build a connector hose...the Banjo should have an 1/8" NPT port for the fuel guage...you can probably find everything you need from a hardware store or auto parts store...
