anyone here use royal purple synthetic?
Re:anyone here use royal purple synthetic?
D1 is king!! ;D I'd say Amsoil series 3k 5w-30 is just as good also, but in a 30 weight. I prefer D1, because it's 5w-40. A close second is the amsoil heavy duty diesel and marine 15w-40, and much more reasonably priced. I've heard scattered things about RP. Same with Redline...
I have Royal Purple in mine now...I won't even debate on whats better...my truck hasn't seized up do to lack of lubrication. I will also note that I work at an oil refinery, and in every compressor, pump, and turbine we run Royal Purple, and haven't had any oil based equipment failure yet. So, with that said; Its all good...use what you want, just change it every once in a while... <br><br><br> Cat Cracker
I'm curently using RP in my current trucks, boat and in all my previous vehicles. I have a friend that used RP in his racing boat, busted one of his oil lines and lost all the oil from his motor. Checked the internal parts for damaged and interestingly enough, no damaged has occured. That my friend should answer your question. I am very please with RP's performance. The more you bomb your motor, the performace gain you're going to get from RP.
I did not think that Royal purple made a Diesel compatible oil. I use to run Royal Purple in my rear diff of my race car. <br><br>Left the engine oil to Valvoline 20W-50..
Roperteacher
07-15-2007 07:11 PM
jeepsuck
12-26-2005 02:17 AM
Ramasaur
01-23-2005 07:13 AM
