Anyone have the Vulcan Apillar gauge kit?
DTR question asker
I've got it and love it. But you may need to make an extension for the trans temp sender if you have an automatic... I have a feeling I will for mine (haven't hooked it up yet).
Location: My head lays down in Murrieta, but the day light hours are spent in San Diego, Ca.
1 Post
For the Isspro tranny temp gauges, yes you will either buy an extension for the temp probe. The factory one is about 12" too short. I actually just extended the two wire myself with 4 but connectors and extra wire.
1 Post
I really like the black faced EV Isspros. The match the trucks gauges cluster. I did also buy the little green covers for the lights, that way at night they will also match.
I got a Boost, Pyro and Trans Temp set from them and I'm very happy with the gauges and Vulcan's service. The trans sender wire was too short so I spliced in enough 14ga wire to reach. I used this to locate the sender: http://www.vulcanperformance.com/ser...-dsh-02/Detail
Its easy to install and the gauge works well.
The A-Pillar was from Glo-Shift but fit well after some minor trimming along the bottom. I picked up some Mopar Camel paint from Geno's Garage and its almost a perfect match to my interior. I would get gauges that match the one's in your dash, mine are black and very easy to read. The green bulb covers do make the white lights a bit green, the dash lights are greener still but the ISSPro's do look good anyway.
ScreaminEagle
01-31-2008 02:33 AM
supr
07-18-2006 08:11 PM
tempoffroad
03-27-2006 06:50 PM
SuperDave4x4
07-09-2005 02:49 PM
