anybody care to analyze/critisize before i seal 'er up?
Old 03-24-2005 | 01:49 AM
swank's Avatar
getting ready to finalize stuff and am hoping for some feedback. due to the constraints of my engine compartment, i think i might have to put a remote mount oil filter on, and the exhaust will be very tricky. other than that, everything seems like it will work. whaddya think? thanks
dave
oh yeah, PICTURE IS HERE
Old 03-24-2005 | 02:13 AM
high country's Avatar
Dave if that thing works half as good as it looks you are gonna need some new tires!! nice work.
Old 03-24-2005 | 02:21 AM
swank's Avatar
i'm hopin so! still runnin the ones that came with it. 2 years ago! thanks.
Old 03-24-2005 | 02:46 AM
joefarmer's Avatar
Is there a reason why there's an extra connector hose between the cold air stages? That pipe will want to blow off the front of the top charger. I think you'll have better luck if you were to weld that connection instead. Mine's solid and I still blew the boot off the top charger once. I can't imagine 2 boots holding the pipe to the housings without reinforcement. Please don't take it as a slam, just something to consider.
brandon.
Old 03-24-2005 | 02:56 AM
swank's Avatar
i'd love to do that, but welding steel to aluminum is REALLLLLLY hard. i ended up getting the v-band clamp elbow (i have a ht3E) for less $ than the ones that pipe is made out of. plus, i don't have to machine the v flange off the compressor housing. you thinking that whole pipe is going to shoot through the grill? i'm going to put some pretty aggressive beads on there. think it'll do? thanks for the heads up.
dave
Old 03-24-2005 | 05:48 AM
59FORD's Avatar
LOOKS GREAT!!
Buckel it up and drop the hammer
You can always add a "safty wire" on the pipe to save the grill
2 cents added
Old 03-24-2005 | 05:49 AM
59FORD's Avatar
BTW
you can always unbolt everything and send it to me ..... I would be glad to "test" it
for you at no charge
Old 03-24-2005 | 08:44 AM
Install the boot with hairspray. That and the beads will keep the boot on I think.
Looks awesome! I love the hot pipe from the top turbo to the bottom turbo, that ought to maximize the flow that the wastegate is capable of. Did you have time to move the pin closer to the pivot to get the flapper opening farther?
Old 03-24-2005 | 09:11 AM
swank's Avatar
actually, i hadn't thought of that one wd. might have to do that before finishing up. thanks for the feedback guys. keep it coming. btw '59, thanks for the offer. i was hoping to find someone to test it for me............just kidding..
Old 03-24-2005 | 11:23 PM
joefarmer's Avatar
Blatently stolen from George's site:
You could use weld keepers on either side of the connection and use turnbuckles to keep them together. Who knows, you may not need them.
brandon.
Old 03-24-2005 | 11:34 PM
swank's Avatar
WOW. that's a pretty beefy setup. it actually shows something i was wondering about. some people use 3" between the turbos and some use 4". kinda wondering what the difference in performance is, if noticeable.
Old 03-26-2005 | 02:43 AM
joefarmer's Avatar
I've got no idea if 4" is better, but it just looks massive in the engine compartment. Again, that's not my truck in the photos.
brandon.
Old 03-26-2005 | 06:05 PM
AlpineRAM's Avatar
Did you mod the wastegate of the top turbo so it will bleed off the front 3 cylinders too? Or do you run an external wastegate?
How do you support the weight of the twins?
I'm really curious since I blew my head gasket and this is an opportunity for me to do some more stuff
AlpineRAM
Old 03-26-2005 | 06:46 PM
swank's Avatar
yes. i drilled the exhaust housing when i ported it a while ago. the majority of the weight will be held by a bracket underneath the turbo. it will function as the oil drain tube bracket as well. gonna bolt it to the 2 empty holes on the engine mount plate deal.
here is a new pic. made a couple adjustments, and then welded. gettin close. i can't wait.
dave
Old 03-27-2005 | 03:03 AM
AlpineRAM's Avatar
This is gonna be a mean one
Thanks!
AlpineRAM
