Any tips for a non fueling TST COMP
I have tried every thing, the box just came back from TST for a bad remote, it worked great for a week, now all of a sudden it just stopped fueling, I took a 60 mile trip and as soon as I got off the the highway that was all she wrote, I re-did the connections at the map, checked the in line fuse and replaced it, put a bluechip pump cover on it, grounded the box to the battery, and still nothin, the box lights up like it should, the boost light comes on when the key is turned, and all connections look good, I even scanned the truck for map codes and got nothin, my last resort is to either solder everything or send it back for another checkup, only problem is now I gotta go another 2 weeks without my box any tips would be appreciated, Thanks
I would remove the box and see if it works nude. If it does, then you know it is the box. If not, it is likely the injection pump itself if you have good pressure to the output side of your fuel filter.
dodgediesel
14
12-14-2006 09:54 AM
dodgediesel
24
10-25-2006 04:40 PM
getblown5.9
13
10-04-2006 04:59 PM
rockjeep73
03-25-2005 03:34 AM
hellotbone
07-12-2003 12:58 AM
