Any Mileage increase with Edge Juice w/ attitude
Old 12-04-2008, 03:09 PM
mudwisr2's Avatar
Originally Posted by 01RAMer
What are you guys doing that got you up in the 20's, and mid teens while towing?? And yes if monitors fuel pressure.
I'm pretty sure that everyone getting those higher mpgs are doing it in a 3/4 ton truck. I don't know of many 1 tons that produce better than average mpgs. Those two extra tires touching the ground sure make a difference dont they
Old 12-05-2008, 02:23 AM
Zeus1987's Avatar
Ok guys, I have a juice w/ attitude, but don't understand what you mean by 3x1 or 3x5, etc. I run mine on level one of 5 levels and only get 18mpg tops out of it, usually around 17. That's about 1 or 2 better than without. Towing 13000 on level 2, I get about 10. I tried running it on level 3 and the milage got worse. What are you guys doing that got you up in the 20's, and mid teens while towing?? And yes if monitors fuel pressure.
If you go into the menu and select configuration then low end responsiveness you will be able to select when the juice tells the VP44 to add full fuel. It is for each level.
Old 12-06-2008, 11:27 AM
mudwisr2's Avatar
There are two settings under the Low Boost Fueling. Do you set them on the same thing and then change the 1 thru 5 setting on the main screen?
For example, I have mine on 2 and 2 under the Low Boost setting and then 5 on the main screen.
I'm looking for the best mileage for towing and I dont have a heavy foot.
Old 12-09-2008, 11:43 AM
01RAMer's Avatar
Appearently I have an older model (ver 1.72) as mine doesn't have this option. I do have an option for "Low Boost Fueling Adj.". Is this the same thing or am I way off base?
Old 12-10-2008, 12:49 AM
Zeus1987's Avatar
no it is the same thing. i just forgot what it was called off the top of my head
Old 12-10-2008, 10:19 PM
sean6oo's Avatar
i get 20 all around no load with my sig 2500 with 3.55 dana 80
16 hwy with 7k
pulled a take 3 car traler with load but did not care about mpg
Old 12-12-2008, 06:18 PM
opiy2k's Avatar
My dually went from 16mpg to 18mpg and a buddy and me both had problems with the turbo timer but it turned out it was just the cheap connection they use. We both changed out the connection and havnt had a probem with it since.
Old 12-12-2008, 09:16 PM
91rangerturbo's Avatar
Yeah i haven't had a problem with the turbo timer. I didn't use the junk fuse adder edge sent with mine. I went and bought a add a fuse and used it.
Old 12-29-2008, 09:24 AM
mudwisr2's Avatar
Update
I ran the Juice on 1x1 with maybe 5 days of pulling about 3k lbs. Mixed city/highway driving the whole tank. The result was 13.1 mpg!!! Not what I was hoping for. I got 13.5 consistently with Diablo Puck pulling 3-4K in city driving daily. I think once I get used to driving with the Juice my mileage will improve.
Old 12-29-2008, 12:44 PM
Zeus1987's Avatar
try 1X4, that is what i normally cruise on. seems to get better mileage than sub levels 1-3
Old 12-29-2008, 07:53 PM
nickg's Avatar
Ditch the 1x1, thats barely over stock, and you have the responsiveness set so low you might as well be stock! set it to level 2 as a minimum as that is what an EZ is (adjust the responsiveness at 4 to start) You have not tapped the pump so your only going to get 60hp over stock anyway, my EZ improved drivability and mileage a good bit. heck your Puck netted you way more power than using edge on 1x1.... I cant give actual numbers yet but I'm running consistantly on level 4 anything less seems slow, veh effort is vastly improved as it takes very little throttle pressure to get up to speed
Old 12-31-2008, 09:00 AM
mudwisr2's Avatar
I have been on 5x5 for this tank. Normally the LOW FUEL light would come on at around 300 miles. I am sitting just over 300 miles right now and still have between a 1/2 and a 1/4 tank left.
Old 12-31-2008, 02:35 PM
Zeus1987's Avatar
tap the pump and then try 5x5 and see what happens. LOL
Old 12-31-2008, 04:27 PM
nickg's Avatar
so did you tap the Pump??
I'm guessing you have seen a mileage increase??
Old 01-01-2009, 09:24 AM
mudwisr2's Avatar
Nope. Haven't tapped the pump. I really would like to but can't afford a new pump right now. Don't feel like rolling the dice.
Quick Reply: Any Mileage increase with Edge Juice w/ attitude
