Any good custom tunes for quad w\pulse?
Old 10-20-2009 | 11:57 PM
Smokin98.5's Avatar
I've been playing around with mine for a month or so and figured someone must have some good suggestion for either good MPG or good all around power? I know every truck is different but..............
Thanks for your time guys.
Old 10-25-2009 | 04:51 PM
Smokin98.5's Avatar
No One?? Bump
Old 10-25-2009 | 07:09 PM
x1phats10x's Avatar
pretty much all i did was start playing with it still workin on mine to get tuned in
Old 10-25-2009 | 08:00 PM
RowJ's Avatar
If you download the ADR1000, ADR2000, Comp, Dyno tunes..... and check each one in the custom tuning...... than right down the settings for each tune, you will get a feel for what needs to change for power, etc. Just compare the different settings on the different tunes and play with minor variations till you find what works for you.
To be honest, I came full cycle back to ADR 2000 for on the street.... latest Comp tune for racing..... Dyno tune for fastest low end response and just playing hard.
Only difference is I set timing to '0' on all three tunes I saved, because I have my ADR stacked on a Smarty....set on odd numbers.
RJ
Old 10-31-2009 | 07:54 PM
RowJ's Avatar
Found my favorite for daily driving..........
Power Levels ............. 5
Timing....................... 8*
Timing Scale ............. 100
Pump Stretch ............ 1800
TPS Max ................... 100
TPS Minimum ............ 30
CAN Bus Max ............. 100
CAN Bus Min .............. 30
Boost Scale ................ 35
5 Prw Levels (optional) gives you .......
1=off
2=Timing advance only
3=Timing and Can Bus Fueling only
4=Half Fuel Stretch Fueling
5=Full Fuel Stretch Fueling
Let me know how it works on your CTD.
RJ
Old 10-31-2009 | 10:30 PM
Smokin98.5's Avatar
Thanks alot RJ. I also emailed quad and they sent me their more defined version of what does what.
Here it is.
File Type: pdf
Clucker
03-04-2015 06:33 PM
ezmoney
05-11-2014 10:17 PM
streetsmoker
09-29-2009 09:11 AM
Pinkston
09-15-2009 07:52 PM
reb0957
08-28-2007 05:54 PM
