Any fix for the rough HRVP44 idle yet?
I havent been around much, but I wanted to see if there have been any fixes for the rough hrvp idle...I tried the search but nothing helped
thanks
thanks
I didn't know there was a problem with them!? Are you talking Industrail Injection SHOVP44? or another brand? All the ones I've installed idle smooth as stock but a little louder.
its not a bad sounding rough idle thats a common problem, its a lope, like a gasser with a big cam. there have been some videos posted where its barely noticeable to one that sounded like john force's dragster rolling up to the line.
my II pump idles just like stock unless its really cold then it has a slight lope until it warms up. i was hoping when i got my IIpump that it would lope at idle but i got one that doesnt lope
Yes...right from Brady. Do a search on here. When the motor has no load like when it is in park or you are cruising with light pedal application it idles like a NHRA dragster. Pretty annoying
mine when cruising down the road barely giving her any pedal i get a funny lope even tho RPMs are up around 1400, just maintaining 30mph thru town...
i even have larger connector tubes now and my idle is still smooth unless i have the TST comp on level 9, then it can get erratic, especially when its hot out!
