any edge guys running with the map sensor permanently unplugged?
Old 02-23-2007 | 11:31 AM
2broke2smoke's Avatar
that's about it ...
i've had mine off for a day and love it ...
with the EZ i only roll smoke with heavy throttle at off idle ...
cleans up quick with the htbg ...
can power brake and put on a show for my 7 year olds buddies
just wanna know if anyone has had it off permanently ... if i don't have to worry about codes i'll just wrap the sensor and the plug in a little electric tape to keep 'em safe
thanks
Old 02-23-2007 | 06:14 PM
scottsjeeprolet's Avatar
I can't get myself to plug it back in either!
Been running without it plugged in for almost a year and no problems yet.
I'm too used to the off the line power if gives me.
Old 02-23-2007 | 07:18 PM
tx_2500's Avatar
i know yall are running a comp box but can i unplug my map sensor with my juice and still run ok?
Old 02-23-2007 | 07:21 PM
Ridiculous's Avatar
been runnin mine like that for a looooooong time. not to worry my friend.
Old 02-23-2007 | 07:26 PM
dieselrob's Avatar
Mines been unplugged for a long time like a yr prolly. No problems with it. Ive had a map sensor code the last 2-3 times ive had a scanner on it but its not setting the light or causing any probs. Man can i lay the smog tho with the 66. The only down side is slight decrease in milage, about 1-1.5 for me but i dont really care. I can run around flatfooting it and use an 1/8 tank of fuel up real quick.
As for the juice most people that tried it said the truck ran like crap when they did it.
Old 02-23-2007 | 11:07 PM
taken5875's Avatar
my buddy has an 03 with the juice and it's un plugged no problems in a year or so
Old 02-24-2007 | 12:39 AM
AAmeeting's Avatar
with it plugged in you get better milage, put a switch on it for when you go on the highway, I do like to roll the coal every now and again.....
Old 02-24-2007 | 01:31 AM
CTD01's Avatar
Juice
Whith the juice it will run like crap unless you jump 5v to the signal wire.
Old 02-24-2007 | 07:28 AM
thanks a bunch guys ...
gonna put a little dielectric (sp?) grease on 'em and wrap 'em in electric tape ..
jlebrun
05-02-2007 08:54 PM
pigsramdsl
04-17-2007 03:06 PM
sledneck1
02-18-2007 06:00 PM
BigBlue
15
05-16-2006 11:54 PM
j
11-23-2002 06:09 PM
Quick Reply: any edge guys running with the map sensor permanently unplugged?
