Any 12v ers ever dyno with just a #10?
Are you trying to compare to the plate/HP chart? A #11 plate is rated 280/680, my 97 with only that plate dyno'd 328/841, about 3/4 forward. It's not the exact answer you're looking for, but a good example. I think the charts are pretty accurate.
These motors respond incredibly well to plates, and bumped timing. That's why I'm guessing you'll be able to go a little higher on the HP.
I did 328 with that #11, and the clutch held for the first two dyno pulls. The third one it let loose, only got 260 or so hp.
I had just the #10 plate, stock turbo, stock injectors and no GSK.. Put down around 330 RWHP.. Had to pedal the throttle as the EGT's went crazy. Mustang dyno in 4th gear.
Well the dyno I was on didn't calculate that correctly. Supposedly around 850 ft-lbs by math. Again the curve looked like Bart simpsons hair as it was pedalled all the way through to keep EGT's below 1300. Not very accurate.
I'm looking at a #10 plate for my 97 auto with the 180 pump.
Chart at PDR shows 220hp and 570 on torque for that combo, does this seem accurate?
How much would HP/Torque increase with a 3K GSK kit?
Thanks.
Thanks.
