Another Gauge Question
I am having a had time finding the right gauges. I need an EGT, boost and fuel pressure. That is easy to find, but I would like to find a single company that makes a fuel pressure gauge that goes up to 30 psi, kinda like the di-pricol one, but I cannot find anyone that has a di-pricol boost gauge over 35 psi, or an egt gauge that does not have that piece of plastic covering up the center of the gauge.
Any help would be really apreciated.
Re:Another Gauge Question
I just put a dipricol gauges kit in my 99. They are white faced. Came from Enterprise engine performance. The boost gauge <br>is a 50lb boost.
WWW.ISSPRO.COM<br><br>Check out the Enhanced Visibility gauges, they have fuel pressure to 30 psi, the pyro is full circle and can get either white numbers or the colored (green, yellow, red) version. I am very happy with mine. Similar overall look as Di-procal (lighted needle, thru lit numbers, etc) <br><br>Mathew
[quote author=Mathew link=board=7;threadid=8464;start=0#81992 date=1040244361]<br>WWW.ISSPRO.COM<br><br>Check out the Enhanced Visibility gauges, they have fuel pressure to 30 psi, the pyro is full circle and can get either white numbers or the colored (green, yellow, red) version. I am very happy with mine. Similar overall look as Di-procal (lighted needle, thru lit numbers, etc) <br><br>Mathew<br>[/quote]<br><br>It seems some pictures are missing on their page, or not working. Can you get them in a white face with the thru lit numbers and needle. That would match the 2003 guages real nice.
Can't get white faced to match 2003 (yet anyway - not sure if they have anything in the works). They make a marine version with white face, blue pointer, and chrome bezel. Might look good but wouldn't match. I just went with the black face, orange pointer. Close enough and look real close at night. I do need to figure out a better bulb cover though - went with green but the factory color is more like aqua. Might try stacking a green and blue cover and see what happens. <br><br>Mathew
Jezzhuntin
08-25-2006 02:51 PM
artesian
08-23-2006 01:21 PM
Boz007
05-05-2006 10:34 AM
Sea:\>Drive
01-18-2006 10:05 AM
Usta HaveA Hemi
02-26-2005 09:37 AM
