Another fuel pressure gauge question, for the 12V folks
Guys
ive done the FP thing before time and again, this is just a concern. I just shut off my FP needle valve (about finger tight) and noticed that My FP gauge was still giving me a reading.
Ironically so, with the needle valve closed at finger tight i now get the readings on the darn thing that im supposed to. It does drop down to 0, but i have seen it as high as 36 psi today in the short while i drove with the needle valve closed.
After some experimenting i noticed that if i open the needle valve to the point where the gauge is pulsating really badly, the needle valve sees as high as 40 psi on some occasions before it gets to 0 or goes haywire on me again,
If i close this thing to just being barely opened up, it reads 10 psi at idle, and pressure steadily goes up as i accelerate to just about 20-22 psi at best,
I do have an identical FP gauge from isspro again that im thinking about replacing my current one with, but i have to ask,,
Whats the deal with my gauge with the needle valve closed? im not certain as towards whats up?
also is my setup, braided line to a connection that connects to boost tube line, affecting my readings as well?
Thanks!
Respectully
Rick
Thanks!
Respectully
Rick
Only problem I can think of with it leaking at closed, is that if you get a leak at the gauge or somewhere inbetween that and the valve, you can't close it off.
I'm going to be adding one here shortly. Stupid thing.
ster1
20
03-06-2012 07:40 PM
