Another F pressure ?, A tad low?
Sorry for going over covered ground again but could not find these same #'s.
I just got my gauges on & have 12 psi at idle, 8-9 at freeway speeds & 6 at WOT. This is from a stock pump system save the last Banjo bolt which is the one that Dieselmanor has with the FP pickup on it. From other threads I seen maybe this is a little low? It shouldn't be the filter as it was changed in the last 2K miles.
Anything to be concerned about or should I be looking at aftermarket systems? Also I have a max of 17 psi boost at WOT is that about average for a stock engine? THX
You got gauges...good
I'd say you've got time to prepare for a lift pump improvement before you start bombing. Keep your fuel tank at least half full with a fuel treatment to combat heat and wear.
mitchgmace
01-14-2007 07:07 PM
Bobcat698
04-22-2005 12:40 PM
