Another cam (fuel) plate question
If you were to move the cam plate in a 12V forward, would it be leaner or richer? What about moving the AFC forward, Rich or lean?
Also, what is a 100 plate? Are they a home brew? What do the HP & lb ft numbers look like with one of these?
Thanks,
Don
Thanks,
Don
Moving the plate towards the front of the engine adds fuel. A #100 plate is a Hot plate that isnt recommended for stock trannies and clutches.. It adds lots of fuel. Yes they are a grind your own.. Here is a pict...
![](http://i35.photobucket.com/albums/d171/HOTMOPR/100plate.jpg)
I have a 100 plate on my truck similiar to the picture above. My question is, do you think there is any fuel to be gained by grinding back further after the intial ramp up?
I tried that on my own plate...went just a hair past the upper mounting surface and I did not seem to feel any difference. When I felt a HUGE difference is when I ground off the ramp up completely, which made mine a #0 plate. I am on the stock clutch and it is borderline holding up!!
Originally Posted by Ironstone
Are there templates for gringing your own fuel plate?
![](http://www.liquidoverdose.com/12vtorqueplate.jpg)
Originally Posted by 12VSuburban
12Valve2nv
Wow, that is an awesome sketch. I had never seen one before. I have mine ground to a 0. Thanks for the sketch. Very informative.
12VSuburban
12VSuburban
![Laughing](https://www.dieseltruckresource.com/forums/images/smilies/laughing.gif)
do a search on fuel plates and take the weekend off to read it
anyways think of the plate as a throttle stop....ur lever arm in the pump does not start on the plate...it starts back from it.....as u use light throttle the arm moves slightly forward but may not ever touch the plate....BUT when u use full thottle the arm goes forward and is "stopped" by the plate and the shape of the plate...so durign full throttle u slide along up the plate ....that is the fueling u get as rpms increase....so as u can imagine the shape possibilities are endless
but unless ur mashing full throttle all the time u may never even touch the plate and the shape is irrelevant which is alos why u can still have the same fuel economy whether u have a stock plate or a flat plate
Originally Posted by 12valve2nv
Thanks for the kudos....but this sketch actually came from a DTR member....I just don't remember which one. If anything, you can thank me for saving it and hosting the pic ![Laughing](https://www.dieseltruckresource.com/forums/images/smilies/laughing.gif)
This is true,
but if your governer arm isnt adjusted, or the arm travels under the plate, well then you have issues, cause it would cause the truck to bog down more than anything..
Rick
Originally Posted by b.lee
im still baffled on how these designs cut into the fuel plate function.
anyone?
anyone?
Here is a link to a cutaway of the pump, it really helped me understand how things work together. http://www.cumminsdatabase.com/read.php?id=182
etn550
04-01-2010 12:12 PM
TexasHardcore
06-28-2007 03:56 PM
drolex
11-29-2006 08:56 AM
