anoother turbo question
I want to go with the BD twins but don't have enough money yet. But I need more air now, so I am going to buy a single. I am going to step up to mach 6's when I get the larger turbo. And eventually add a smarty. Right now with my Hx 35/14 cm housing on level 3 sub level 4 on the edge I can spin the tires in first and into second gear. I also see about 35 to 40 psi of boost. I want to be able to spool the new turbo like like the Hx35 spools. Is this possible? I like the power right off the line.
Registered
if you want a turbo that is upgradable to twins later on down the road, get the sps 62. It will cool what you have now with ease, and you can easily throw a b2/s400 primary under it for one heck of a twins set.
That is good advice too.... and seems to be gaining popularity too. I guess its kind of like building your own computer instead of buying one from Dell .
j
01-09-2004 08:19 AM
Haulin_in_Dixie
07-21-2003 11:14 AM
redram
12-10-2002 09:54 AM
