AMSOIL Antifreeze
Old 02-18-2005 | 03:02 AM
rmrc's Avatar
Question AMSOIL Antifreeze
Has anyone used the AMSOIL antifreeze?????
I'm considering using this for it's,,,, supposed superior antirust qualities not to menetion it's longevity. It's compatable with all other antifreezes.
When I heard about it's metal protecting advantages, and being that I'm a "53 Block" member, I thought it might be a good idea to switch over as a maintenance procedure against the 53 cracking. The truck is due for a coolant change.
Any opinions or experiences????
Old 02-18-2005 | 10:03 AM
infidel's Avatar
My feeling is when ever you use a expensive coolant Mr Murphy comes along and a hose, water pump, etc fails and you lose it all.
Old 02-18-2005 | 10:25 AM
BoostdCTD's Avatar
If you want a good aftermarket antifreeze look at Evan's Waterless. It has a boiling point around 370*F, so there is no longer a need to pressurize the system. Without the pressure surges it'd take the sysem a very long time to ruin a hose or radiator as all it is doing is holding fluid, nothing more. The price is quite expensive ($25/gal) but if it saved a break down, hose rupture, radiator, ... it is all worth it, IMO. It also never has to be changed, ever. They actually suggest you can transfer it from vehicle to vehicle but....
http://www.evanscooling.com/main23.htm
Old 02-18-2005 | 12:13 PM
infidel's Avatar
Fleetguard ESXtreme coolant is good for 600k, costs $13/ga
read about it here> http://www.cumminsnorthwest.com/News....asp?NewsID=18
Old 02-18-2005 | 01:46 PM
BoostdCTD's Avatar
But that is still a water mix right? That is probably the best water mix out there but I think it'd be real nice to escape the pressure and the problems/wear caused by it.
Old 02-18-2005 | 02:27 PM
phox_mulder's Avatar
I 2nd that.
Made by Cummins for the Cummins, can't go wrong there.
phox
Old 02-18-2005 | 02:30 PM
BoostdCTD's Avatar
Well made by Fleetgaurd for the Cummins at least.
Old 02-18-2005 | 02:35 PM
Fleetguard is Cummins.
http://www.cummins.com/cmi/content.j...10&menuIndex=2
phox
Old 02-18-2005 | 02:50 PM
BoostdCTD's Avatar
Learn something new everyday.
Old 02-18-2005 | 06:38 PM
infidel's Avatar
phox
Didn't realize till clicking that link that Holset is a division of Fleetguard.
Old 02-19-2005 | 09:26 AM
TPilaske's Avatar
Gee... and you wonder why they recommend Fleetguard for everything...
Old 02-20-2005 | 12:04 AM
BoostdCTD's Avatar
Well not really, even if Fleetguard wasn't made by Cummins it still is the best (oil) filter you can get for the CTD.
Spooler
28
12-26-2009 10:16 AM
jpsawyer
06-14-2009 07:12 AM
czkid
10-18-2007 07:38 PM
dodgediesel
09-23-2007 03:27 AM
fitzydog
06-06-2007 09:40 PM
Quick Reply: AMSOIL Antifreeze
