Almost cracked 700 HP
Old 07-21-2003 | 11:21 PM
Battering Ram's Avatar
Re:Almost cracked 700 HP
With a larger set of twins, a cam, and some better atomizing injectors of the same size you might be surprised how close you are to 800hp withought adding fuel and losing drivability. At least a 40 on top is next for you then maybe something bigger on the bottom too. Just know that I'm working on it for you .<br><br>Horace
Old 07-22-2003 | 09:35 AM
Jim Fulmer's Avatar
The 40 on top and a cam are in work but it just depends on timing, I'm heading back up to Canada in Sept. so I need some cash for that....yes I'm driving the truck! Injectors would no doubt help as 370 aren't the best, there just cheap. I very seriously doubt I'll buy any, someone would have to furnish them to me. I have plenty of fuel, it's just rude rich but surprisingly low EGT's for the power output.<br><br>Jim
Old 07-22-2003 | 11:16 PM
Southern Ram's Avatar
Jim,<br> Are you going to coat the pipe work when you redo your twins with a HX40 for your small turbo? I am going to be getting a set of twins from PIERS and I am trying to decide if I should go ahead and have everything coated. <br>Good job on the high HP run.<br><br>Todd
Old 07-23-2003 | 06:45 AM
Jim Fulmer's Avatar
Hey what happening Todd, yea I'll get the hot stuff black high temp coated and the cold stuff chrome ceramic coated like I have now, too many people look at it and take pics not to make it look good, that is the Twin setup I'll be running too!<br><br>Jim
Old 03-16-2004 | 11:53 AM
Superduty12v's Avatar
Muted User
Jim, How much boost pressure were you running when you were near the 700hp mark?
Old 03-16-2004 | 01:15 PM
Jim Fulmer's Avatar
Which set of turbo's? 35/HT3B were 65 on the street, 60 on the dyno. The new set is 75 on dyno 80 on the street, I've done 80 on the dyno and 100 on the street would be as easy as closing the pop off's.
Jim
Old 03-16-2004 | 03:31 PM
Don M's Avatar
DTR Advertiser
Jimbo, Im sure you told me, but is the 75 PSI with the Methanol or just straight diesel?
While I got you on the line.....is your camshaft stock?
Thanks Man,
Don~
Old 03-16-2004 | 06:25 PM
MCummings's Avatar
Hey Jim,
I was curious.. Is your Cam OE? I wasn't sure if your cam was stock or not...
Merrick
Old 03-16-2004 | 08:42 PM
bigred496's Avatar
holy crud that is awesome, good job jim
Edited by Admin
Old 03-16-2004 | 09:56 PM
Jim Fulmer's Avatar
I didn't notice a difference with the water on or off, all three runs were at 75 at least by the tale tale, when I did the 80 psi run here in OKC I had the pop offs capped but that was fuel only.
Yes the tired old motors cam is stock.........I think I'm at a wall
Jim
Old 03-30-2004 | 08:54 PM
MTCUMMINSMAN's Avatar
Hey jim what kind of plate do you run in your Piers race pump?
Old 03-30-2004 | 08:58 PM
Jim Fulmer's Avatar
A stock one!
It's cut, then the pump tuned to it on the pump stand. No I don't have a picture but it's not a zero plate.
Jim
Old 03-31-2004 | 12:08 AM
nascar mark's Avatar
Old 03-31-2004 | 03:19 AM
MCummings's Avatar
Originally posted by Jim Fulmer
A stock one!
Did I just see a cow fly? or Did Hell Freeze over?
Merrick
Old 03-31-2004 | 07:35 AM
Geico266's Avatar
Hats off to you Jim! Thats close enough to 700HP in my book. The dyno could be off that much!
