Allright I need help finding 20" wheels with deep backspace and longer control arms
I think I've decided the way to go for tires is to run 41" military tires. there about 12" wide. They need a 20x10" wheel but I cant find any steel or allum though I prefer a alluminum. That have the correct backspaceing. My guess would be something like 6.25-6.5" to keep the wheel centerd like the H2 is (slightly out from stock) Any one have any ideas? Also I have the skyjacker 4.5" lift that came out to be about 6" of lift. I need to center the front axel to try to fit those 41's under there without a bigger lift. I guess about 1-2" farther forword. Does anyone make controll arms longer then the skyjacker ones to do this? I dont really like the idea of "adjustable" ones and I dont want to goto the long arm kits. Failing all of this if I put 2" spacers on top of my coil's to give me more lift is there any reason why this would be a bad idea?
Thanks
Thanks
im not really sure. I only go by backspaceing. I think I can run a 20x9 since I'm not really running the tires at max load (over 4000# a tire I think) then id need like a 6" backspace.
smokinram99
11-18-2008 09:02 PM
silkywoods
14
04-29-2008 12:35 PM
Scramblinman
10-16-2006 05:36 PM
