Allison transmission on a Dodge RAm
#31
Originally Posted by Haulin_in_Dixie
A set of rv275 injectors and it will outpull any of our engines. As it is it probably will be more powerful than the stock second gen engine. It is lower rpm, thus lower horsepower, but check on the torque, it is probably higher than our engines. I am running the commercial engine would not go back for hauling. Mine with the EZ has never been passed up a hill loaded by a mid or pickup sized truck like loaded. The last engine was rated at 190 horse and with the rv275 injectors was almost as strong as this engine.
#32
Originally Posted by Valv
Well I disagree with all the posts that says it cannot be done. Cummins ISB + Allison transmission is done commercially for some companies.
The one I was interested is on a Freightliner MT55 Fedex delivery van.
It has a Cummins ISB-02 185 with an Allison 2400 transmission.
Only neg issue is adapter to tranfer case, which I believe is same as 1000 on GM trucks, and the output of motor is only 200hp it will need "pumped up" a little, but it's the newer version of the 5.9 ISB.
I decided to go with a good ol' standard 47RE, but if somebody is interested in the combo above, it will sell for approx 6,500, but you will get the whole van (2004 Freightliner M55)
Check Freightliner web site for more details.
IM A DETROIT DIESEL/ ALLISION TECH. THE ALLISON IN THE DURAMAX IS ONLY A 1000 SERIES. IT IS NOT 600LBS EITHER. THE TRANS THAT COMES IN THE OLDER FED EX VANS OR UPS VANS ARE EITHER A 545 OR A 645. THE NEWER VANS HAVE A 1000 SERIES IN THEM. AN ALLISON CLUTCHES ARE DESIGN TO TAKE ONLY 50 TO 100 HP MORE THAN AN A MEDIUM ENGIN CAN PUT OUT . YOU WOULD BE SURPRISED WHAT YOU FIND AN ALLISON IN!!!! EVERYBUS ON ROAD HAS AN ALLISON THATS A HD SERIES(4000) THEY WEIGH ABOUT 700 TO 900 LBS. MOTORHOMES ALL HAVE ALLISONS TOO. THOSE WOULD BE THE MD SERIES(3000). MOST OF YOUR SMAL COMERICAL TRUCK, VANS, AN OTHERS WOULD HAVE A 1000 ,2000 OR A 2400 SREIES.
THE 1000/2000 ARE THE SAME SIZE JUST THE IN TERNALS ARE A LITTLE BEEFER. THE 2400 IS MORE OF A MANUAL TRANS THAN A AN ELECTRONIC TRANS LIKE THE 1000,2000,3000, N 4000 SERIESYOU A FEW THINGS TO MAKE IT WORK IN OUR TRUCKS.
Valv
06-30-2005 08:20 AM
