Allison tranny
Old 02-01-2007, 11:03 AM
  #331
duratothemax's Avatar
Originally Posted by Brayden
Yeah.. That someone bleeds purple... ATS has had that controller on their site for 4 years "coming soon".
They don't tell you about that controller that magically jumped a trans into reverse going 60
and applies all the clutchpacks (c1-c5) at once if you put the shifter in neutral
duratothemax is offline
Old 02-01-2007, 11:33 PM
  #332
LanceD's Avatar
what happens then?
LanceD is offline
Old 02-02-2007, 06:46 AM
  #333
gunracer1's Avatar
i have a friend that has a full blown ats in his duramax. with the new billet flywheel. something happened and it sheared off all the torque converter bolts. sounds a lot like this.
gunracer1 is offline
Old 02-02-2007, 07:55 AM
  #334
Brayden's Avatar
Well ATS in their infinite wisdom designed a BILLET flexplate.. hmm... How does a flexplate "FLEX" if it's made out of billet?
Flexplates are supposed to flex. But they must know something that we don't.
If all clutchpacks were applied at once, you create a transbrake, a very good one at that! Which isn't a bad thing when you're stopped. But is very bad when you are going 60 mph.
Brayden is offline
Old 02-02-2007, 08:14 PM
  #335
Hammily's Avatar
Where do you get the right bellhousing and flexplate for the conversion?
John
Hammily is offline
Old 02-02-2007, 08:27 PM
  #336
Brayden's Avatar
PM me, I can get you set up with what you'll need.
Brayden is offline
Old 02-03-2007, 12:03 AM
  #337
LanceD's Avatar
can you set up the PCM with a switch that will engage all the clutches? Im thinking it would make a good spoolup tool for launching at the strip, like the drag cars do. I rode in a mustang auto with a blower and stuff, the guy had a trans brake or something in the tranny, he put it in drive, floored it, hit a button and my head hit the seat haha, it was a rush!
LanceD is offline
Old 02-03-2007, 12:45 AM
  #338
cumminsdriver635's Avatar
Holding the brakes, and building boost will do the same thing. Seems like it wouldnt be as hard on the tranny as a transbrake, but I really dont know. I know when my cousin(teddybear) does a 15lb launch with his built Goerend it feels like you are on a roller coaster. it puts your stomach in your throat
Gabe32: Is there any way you could get video of something like a standing start WOT run with the camera viewing the tach/speedo? I think a lot of us here would like to see that to see how well it shifts etc. Im sure the only real way to know much about it would be to ride in it, but just a video would make it a lot easier to understand how it shifts. Or even a video of just some driving around would be cool. Its understandable if you cant get video of it, but it sure would be cool
Eric
cumminsdriver635 is offline
Old 02-03-2007, 06:24 AM
  #339
Gabe32's Avatar
I will see what I can do. I will try something when the weather breaks a little
Gabe32 is offline
Old 02-03-2007, 10:49 AM
  #340
im 99.9999% sure no, all of the solenoids are PWM, and the factory allison TCM has too much safety built in to allow this.
Old 02-03-2007, 12:35 PM
  #341
patdaly's Avatar
I'm pretty sure at the level of torque you guys are putting out, that there isnt a chance in heck that you could get one to survive a trans brake launch.
Lets put it this way, if you could get the tranny to survive, having the rest of the driveline unloaded and shocking it with that much torque wouldnt be pretty.
My 70 Nova with a blown 489 is pretty rough on even super duty driveline components, and its only in the 1K ish torque range when I let go of the button.
patdaly is offline
Old 02-03-2007, 12:38 PM
  #342
Brayden's Avatar
Ben,
There are only 3 of 7 solenoids in the trans that are PWM. The rest are on/off. 3 of 6 on the early stuff.
Brayden is offline
Old 02-05-2007, 12:28 PM
  #343
the 3 shift solenoids arent PWM? hmm didnt know that thanks brayden
when are they going to variable bleed solenoids?
Old 02-05-2007, 02:02 PM
  #344
Mcmopar's Avatar
Please forgive my ignorance, what is a PWM solenoid??
Mcmopar is offline
Old 02-05-2007, 02:20 PM
  #345
John Faughn's Avatar
Pulse with modulated , further deff. , the frequency of the pulse regulates the fluid that pases , same with fuel injectors .
John Faughn is offline
Quick Reply: Allison tranny
