Allison tranny
Old 11-27-2006, 06:26 PM
  #166
signature600's Avatar
You might check with www.transfercases.com...they might be able to build a 271 with a sensor location??
Just a thought!
Chris
signature600 is offline
Old 11-27-2006, 06:53 PM
  #167
HiJenks's Avatar
I started reading this thread before Thanksgiving and was very interested in the swap as my tranny has 97K on it and is used 95% for towing.
My son just got his 2007 Chebby 2500HD with the allison and I got to see what the 6 spd with tow (manual) could do.
I'll be checking with you for more info !!!
HiJenks is offline
Old 11-27-2006, 07:15 PM
  #168
Racing_Joe66's Avatar
what do u mean difference in size on the adapters?? thickness or what?? i know someone that has one but he doesn't know how to tell either. so we are trying to figure it out.
thanks,
joe
gabe pm me back or call me.
Racing_Joe66 is offline
Old 11-27-2006, 09:19 PM
  #169
u say the flexplate is cummins and is solid. but a little before that u said "absolutely everything is changed. There is not a dodge part left from the flywheel housing back."
so if u change the flexplate then what cummins one do u use?? off a bus with a cummins motor and an allison trans?? or any aftermarket solid cummins flexplate will work as long as its solid??
thanks
Old 11-27-2006, 10:38 PM
  #170
Gabe32's Avatar
the flexplate is a cummins and not a dodge. It is off a medium duty cummins with allison.
Gabe32 is offline
Old 11-27-2006, 10:46 PM
  #171
any allison trans behind the cummins 6BT or more like a AT545 trans??
i know someone that has an adapter plate which is off of a Chevy - Grumman/Olson 17 foot stepvan, 1990, with a Cummins 4BT, which had a TH400 transmission. The adapter plate is to mount the TH400 behind the Cummins 4BT or 6BT engine, so it's a Cummins/GM
adapter plate.
would this adapter plate work?? also have the flexplate too. don't know if it would be the same for the allison. anyone know??
Old 11-27-2006, 10:49 PM
  #172
Gabe32's Avatar
Won't work, different. AT545's had different variations of the housing. It is hard to tell if it would work or not. All that other stuff is different that your friend has.
Gabe32 is offline
Old 11-27-2006, 10:53 PM
  #173
so would have to find a medium duty truck with an 1000 or 2000 series allison and the cummins to get an adapter?? and the flexplate off it too?? i found somewere though that the AT545 adapter was an SAE #3. or are there different SAE #3 adapters??
Old 11-28-2006, 02:21 PM
  #174
displacedtexan's Avatar
Semi OT-
How hard would it be to bolt up an Atlas transfer case? That way you could have easy 2 low, and it should be more than strong enough.
displacedtexan is offline
Old 11-28-2006, 03:50 PM
  #175
LanceD's Avatar
I am curious about this too. in fact, who knows what transfercases will mount behind the allison besides the GM 261?
LanceD is offline
Old 11-28-2006, 04:01 PM
  #176
It seems like you can bolt the Atlas to the Ally, not a direct bolt up, but doesn't sound to bad either.
http://www.atlas-tc.com/download/SelectChart.pdf
Old 11-28-2006, 05:08 PM
  #177
what kind of variations are there in the AT545----SAE #3 housing and an 1000-------SAE #3 housing?? will the starter and flexplate off an cummins to AT545 work??
Old 11-29-2006, 04:23 PM
  #178
LanceD's Avatar
does the GM 261 have a PTO?
LanceD is offline
Old 11-30-2006, 04:16 AM
  #179
FDPOWER's Avatar
there is an at 545, 645, 748. the flex plate off a 545 will not work. totally different
FDPOWER is offline
Old 11-30-2006, 10:02 AM
  #180
duratothemax's Avatar
Originally Posted by FDPOWER
Well I have sat here long enough a read to many false hoods about the allisons. So this is my 2 cent. im an alllison technician so here it is. An allison is proably the best trans on the market today. Allisons are in ever thing, buses,motor homes, trucks,tanks , fire engine ,etc. A built allison is beter than any ford or dodge trans. Now on to the next half. To get the 6th gear its all in the programing. Since you are not using the 1939 comunications with the tcm you have all u need in engine speed, turbine speed an trans output speed . Also power to the tcm an she will work. it wont throw an codes the will stop the trans from shifting. an since your not using the 1939 communication you will never see the check engine lite.
not to disagree with you because you are an "allison tech", but no it will NOT shift without J1939 data. That is NOT a standalone TCM, its a standard 3rd gen Allison TCM just like thousands of other trucks use. SO If its so standalone and only needs input speed, turbine speed, and output speed why the hell does he have like 50 wires running into it??? Yeah you can make the truck move without even having a TCM hooked up, but it will default to third gear and obviously not shift. The solenoids are set up to default to a certain N/O N/C fashion (if all power to the trans is cut) to allow the trans to limp home (in third gear) even if the TCM buys the farm or completely vaporizes for some reason. Beleive me I have tried LOTS of things with my trans and TCM and have somewhat of a good idea of how it works. If that DID work like you say it does, there would be hundreds of 12valve cummins's out there running LCT's. Just because the dedicated MIL-request wire is disconnected (no it doesnt do MIL requests thru J1939 like you say it does) do you think it wont throw any codes??? No, it doesnt care whether it tells you or not, if it wants to limp it WILL limp. Just for kicks I disconnected everything from my TCM except all the obvious PNP/NSBU wires and solenoid wires. Did I get a check engine light? NO. Did it shift and work normally? NO.
so I guess the TCM doesnt need any APP wires either?? Its THAT smart that It can vary shift points by using telepathic powers to know where your foot is??? Every automatic trans in the world has some sort of throttle pos sensor, whether is mechanical (TV) or electronic (APP). How would the trans know when to kick down? How would it know how much torque the engine is deleivering? How would it firm the shifts when you go WOT under full power? Youd slip the crap out if it IF it even shifted at all. You would probably even get a tie up because it has no idea what fill rates and apply pressures to use as far as controlling the trim solenoids and PCS.
guys you are welcome to try this on your mechanical 12valves, but you'll be wasting 600 bucks on a TCM that you cant use, and 3,000 bucks on an Allison trans that wont work.
ben
duratothemax is offline
Quick Reply: Allison tranny
