Allison tranny
![Question](https://www.dieseltruckresource.com/forums/images/icons/icon5.gif)
What would I need to do to put a 1000 series allison auto behind my cummins in a '02 extended 4x4? My truck has the 47re in it . Does the allison need to be from a 4x4 also? Thanks.
I can do the swap for you. ATS has never done the swap because they don't know how yet. I know this for a fact. An allison is a superior tranny to a 47 in many ways. I also know this for a fact. The tranny conversion is just as cheap as a stage V ATS with way more features.
that is a argueable question. I will say it like this: The allison in STAGE 4 form, I would say is stronger than a stage V ATS. I have sledpulled this season with mine and it never broke or slipped. I know of several ATS and Suncoast trannies with billet shafts that have busted. I am not talking bad about there trannies but there is only so much room to work with the 47 and 48re trannies. The shafts are too small and that is why they still break the billet ones. Do a search on "broke billet shaft trannies" and you would be kinda surprised at how many break. I am not trying to start a war by any means, I have had both trannies and the allison is by far the much better tranny. THAT IS MY OPINION!!
This is for a STAGE 4 allison. It is comparable to a ATS. That is the ATS with the stand alone controller. There aren't any computer issues like there are with the dmaxes. It is a completely different program. I have been driving mine for about 13,000 miles now with no problems at all.
Im goin to have to do a tranny job cause it is a known fact that the 47re is weak. Im just trying to ask some questions to find out if it would work putting an allison in and if it would be cost comparable to redoing the 47. I know I would have to do a complete rebuild and VB and torque converter and I figured if im goin to spend the money to do it right maybe spend a little more and get the allison. Im not sayin the allison is superior over anything else. It is just that I like that particular tranny. I dont intend to start any wars here. Just asking questions because I want to know . I want to start turnin the power up on my cummins but I cant now because of my stock tranny. Thank you to all for your comments. Great people here!!
To my02CTD, there are many, many good options on building the 47re that hold a ton of power. You may find a less expensive option going that way or put a built 48re in it for that matter. Dave Goerend has a great tranny for the $ by all accounts here. There are many other good vendors too including DTT, Suncoast, ATS, and HTS that all hold mega torque and horsepower. 47re may be a little weak in stock form, but not at all when built by a performance builder. Main thing would be to find a reputable builder in your area that can take care of you conveniently no matter what option you go with unless you are able to do the work yourself.
Good luck, Matt
I'll bet there's a lot of people interested in this.
Can you use the school bus Allison, or where do you get the 1000?
How does the transfer case hook up?
Is the Allison TC better?
Can you give a rundown on whats involved in the swap?
Gabe- please PM me with more info about this. I have a 12v with a 20 day sticker on the back window, and REALLY want to start bombing it, but don't want a band-aid fix for the tranny. I realize there are some awesome tranny builders for our 47s, but don't you get another gear with an alli?
I considered this swap after talking to Gabe, but I had already purchased billet inputs/outputs, etc so I kept my 47/48 hybrid. The shafts in the allison are much larger than those in the 47/48. The pinions are much larger too, that is itself will handle more torque (if the materials are equal)
For my next truck???? Maybe
A school bus allison is not a 1000. You can use one, some buses use a 2000 series but the internals are the same as a 1000. I have a place where I get the 1000. The transfer case is also out of a duramax. I put a triple disk goerands tc in all the allisons. You can use a dmax convertor but the stall is too high for a cummins. A very quick rundown is everything from the back of the engine is different; housings, starter, cooler, tranny, tcase.
