? to all the guys running 1/2 fuel lines & non stock filters
tommorrow i'm putting a holley blue on with 1/2 lines and pickup and looseing the stock lift pump b/c it bit the dust..
what did you'll do about the stock return... did you leave it alone or use the stock feed as the return...
i also want to get rid of the stock filter... but what happens when you unplug the two plugs on it?
the truck is a 2000..
One plug is for water in the fuel and the other is the fuel heater.Just tape 'em up,
some applications don't use 'em anyway and they are capped off.It won't hurt any thing.Oh if you don't tape up the water in the fuel and you get oil or water in the plug it will think it has wter in the fuel and will derate the engine after enough counts.
GaCamper
01-18-2009 11:05 AM
fitzydog
10-12-2007 11:23 AM
36
06-04-2003 03:30 AM
