ajustable boost controller
#32
Which box and injectors you planning on going with? For the VP trucks you almost need little larger injectors plus a box to get to 35psi. The 35psi limit is that the turbo is on its maximum limit and will start pushing more heat than cfm (just not as efficent) Guys have run them to 40psi, the HX-35 turbo is a pretty tuff turbo.
i don't want to go much (if any) more hp until i get the tranny rebuilt to handle higher hp levels.
i'll update my sig later today so you can see where i'm at.
anyone know the hole size to drill for the bleed orifice after the set screw on the boost elbow?
Artcabinets
10-05-2011 05:08 PM
SuperiorRam
02-03-2009 04:14 PM
bullboy85
11-06-2007 08:34 PM
