AirDog raptor 150
I did an Air Dog 150 on a 01.5...
This is where I put the draw straw...
Pump mounted. Sorry you can't get a lot of details from this pic...
I did run a return line.
What do you need to know? I pretty much just followed the directions in the book, they are pretty good. The only problem I had was with the ECM putting enough power to the pump to push enough to the VP to start the truck... on this specific truck, I had to wire in a switch to power the pump.
I installed one in my 2000. Really easy install. The wiring goes from the battery to a relay triggered off the factory lift pump wiring. Plumbing, they give you a quick connect to tie into the factory pickup off the tank, unless you have the in-tank retrofit. Then it plumbs right in to the side of the filter housing. Everything's provided. I have pics, but don't have them uploaded.
From what I recall, you can't pull through the in-tank pump. I think you've got to pull the bed or drop the tank and install a drawstraw.
My 2000 didn't have an in-tank pump so I didn't have to worry about that. I have a drawstraw 2 sitting in my garage if you need one. I bought one thinking I needed it, but never used it.
CrashCade
12-03-2008 08:58 AM
53 willys
38
11-06-2008 12:18 PM
dodgediesel
26
11-02-2008 01:20 PM
goose2w1
02-29-2008 09:45 AM
84mphcdt
16
12-19-2007 12:31 PM
