airdog install
airdog install
I bought a airdog off of a wrecked truck and it came with no instructions. I hope someone can help me with a few questions. 1,Do you eliminate the stock lift pump and filter and run a new line from the airdog to the vp. 2,On wiring it up does it need a relay put on it and do you tie into the stock pump wiring to power it. 3, On the return line from the pump to the tank where do you tie the return line into. Is there anywhere online that shows install instructions for the airdog install. Any help would be appreciated to make this an easier install. Thanks,Gary
gwhammy
You can find the install instructions here:
http://www.eckstamworldwide.com/manuals/DODGE.pdf
The system is intended to bypass the stock LP and fuel filter, it should have it's own relay for power and hook up to the original lift pump to power the relay only.
Good luck
mishkaya
Good luck
mishkaya
kdbvulcan
20
12-06-2008 04:34 PM
