Airdog help
Airdog help
Just installed airdog 150 and am getting 23psi at the vp at idle. Is there anyway to adjust the pressure down a touch?? Been told that anything over 20psi is hard on the vp pump seals. Thanks for the help
Guest
Posts: n/a
PM sent... A long one haha! I dont think the pressure where its at will be a problem on the 01. But your pm I sent you will tell you have to fix it if you choose. Any type of kink in a return, this can be a very minor kink will cause the pressure to rise. Just a little FYI for you guys.
Mine does the same thing for the past year and half since the airdog install never been an issue. my boy has some other pump inline with his stocker and about same pressure has not been an issure for his truck either 2nd gen 24v. ED
kdbvulcan
20
12-06-2008 04:34 PM
roxj
02-17-2008 12:36 PM
