Air Ride suspension
Air Ride suspension
The Truck a 2001 Dodge ram 3500 that tows Cigarrete boats all over the east coast to poker runs.
The system ART HD Airbar out back and Cool ride up front, A Dakota Digital Preasure and hieght auto adjustment system, A Pair of Viair Comps, 10 gallons of Stainless tank, Asco Manifold valves and some Stinger relays and circut breakers.
Truck getting ready for the install.
Old rear suspension
Getting ready for the new setup.
4-Link and airbag installed
Front Airride installed
Air Managment installed
Dropped!
Old rear suspension
Dropped!
Just looked at the pictures again & realized your truck is 2wd, I probably would have put it in the weeds too. Looks bad!
I like it. Did you weld the top 4-link bracket to the frame, or did you use existing holes?
Since you have on-board compressors, what is the purpose of the air tanks? Are they for suspension compression volume?
What PSI do you expect to use?
The 4-link top bracket bolted on, Very user freindly. The compressors fill the tanks then the tanks in turn supply air to the manifold which fills and releases air from the airbags. Without the tanks it would take 5 + min to go from drop to lift with the tanks it takes all of 1 second.
