Air Intakes...
Air Intakes...
Ok so im about to order an air intake for my truck and I found an S&B kit for 231 and then I find an AEM kit for like 4 something....why the big difference.....they both have the same setup with the fitler, box, and tube. So am I missing something here or what??
check out DTR , they have nice intakes that work for cheap.
i have the quad intake and love it. the scotty is nice also.
thanks dieselfan
AEM Brute Force runs around the same as the S&B. Fram Boost is just under $200 and, I'm led to believe, uses the same AEM dryflow filter that's in the Brute Force ... I haven't confirmed this, but it sure looks a lot like it!
There are lots of options becoming available for our trucks..... Some are good others not quite the option you may want. We have done a lot of dyno testing on different filter setups and the only one that made HP was the AFE units. In fact the BHAF actually decreased HP by 4-6 on the dyno.
Doug Smith
Doug Smith
If you want you can use the tube off the stock box with the filter of your choice then fab up your own heat sheild or box. Even a replacement afe pg7 filter is only like $70.
coastal_diesel
17
03-18-2005 02:35 PM
genros
03-12-2005 04:57 PM
coolslice
06-24-2004 09:16 AM
