air horn mounting?
air horn mounting?
anyone have a good place too mount a set of airhorns?? I have a temp spot mounted too my battery on the turbo side...but was wondering if there was a better place too mount them so they are not in the way if i doo something under the hood?
Thanks,
Jon.
Thanks,
Jon.
I installed mine using these instructions.
http://dodgeram.info/tech/mods/AirHorn/index.html
The Horns mount on the lower radiator support, the Compressor, sits where the old electric horns used to sit, the Air Tank on the frame rail on the passenger's side.
On my '99 I remover the rt. bumper brace (attaches behind fender). I then drilled one hole to mount the horns. They will have a natural slope to the center of truck so no water will accumulate. I thenmounted the tank to the frame under rear seat & hung the compressor (oilless) Sp?upside down under bed just behind the cab . I left the stock horns in place & used the stock relay. If I just tap the horn button the air horns do not sound.
Jim
Jim
BigDogJeepin
06-05-2010 08:13 AM
63wagon
04-28-2009 08:56 AM
DF5152
10-30-2003 06:11 PM
