Air flow and BHAF
Originally Posted by sothern thunder
all i no is that i put a napa bhaf on my truck and it is stronger and responds as soon as u give it the coal so i think its great so far
![Whistling](https://www.dieseltruckresource.com/forums/images/smilies/new1/whistle.gif)
Here is the catalog page for the BHAF. It is a Donaldson 105006. 680 CFM at 8 in H2O. Notice how it has the flow AND the pressure. You need both to have a meaningful comparison.
![](https://www.dieseltruckresource.com/pics/data/500/3440834408BHAF_table.jpg)
If you need to see more of the catalog to be sure I am not pulling your leg, check my gallery.
Here is the text from a stock Dodge filter. Max flow is 19.12 m^3/min = 675 CFM. That is probably where Wix got the number from. Notice the "pressure loss @ max flow" is 0.035bar, which is 14 in H2O. Not 8 in H2O. At 8 in H2O, this filter will flow about 510 CFM.
DON'T POST FLOW RATES WITHOUT PRESSURE. It only confuses the issue.
![](https://www.dieseltruckresource.com/pics/data/500/34408dscn0009.jpg)
The dyno isn't real world, and doesn't make up for air flow around a moving truck, but is a much more controlled means of testing than seat of the pants. My question is if you can't see increased spoolup on the dyno, in a controlled test, which should show a faster horse power rise and more area under the power curve, then how the heck are you ever going to feel it on the street?
Superduty's #'s are right. Here's a link that will show the same thing for that filter: http://www.donaldsonfilters.com.au/u...ew%20Draft.pdf
ralphyboy
01-17-2008 08:35 PM
8mpg
05-22-2006 01:35 PM
