Is this AIR FILTER safe for my truck?
I am running a K&N filter with the stock housing. A few guys at work said they would never run it cause they have noticed that the fine glaicer dust makes it through the filter and into the turbo. They have seen the fine powder on the turbo side of the box. I have been checking mine every week and have had no problem's yet. Thinking of going to the ScottyII system, how does that handle fine particals?
Re:Is this AIR FILTER safe for my truck?
[quote author=02DSLDOG link=board=7;threadid=12263;start=0#116088 date=1047683473]<br>I am running a K&N filter with the stock housing. A few guys at work said they would never run it cause they have noticed that the fine glaicer dust makes it through the filter and into the turbo. They have seen the fine powder on the turbo side of the box. I have been checking mine every week and have had no problem's yet. Thinking of going to the ScottyII system, how does that handle fine particals?<br>[/quote]<br><br>I have used the K&N filter for 2 years without any trouble....if you have a good seal you'll not get any grit into the motor...donot open the filter box to check your seal just pull the turbo hose off the turbo and wipe the hose with a clean white cloth to check for grit...also wipe the turbo inlet
Location: Drive till ya hit a Polar Bear, then go back 50 miles
[quote author=02DSLDOG link=board=7;threadid=12263;start=0#116088 date=1047683473]<br>Thinking of going to the ScottyII system, how does that handle fine particals?<br>[/quote]<br><br> Boy we've had alot of these threads lately. <br><br>The aFe 20-40044 has a filtration efficiency rating of 97.9% (aFe rating) while the stock air filter is rated at 98.4% (Fleetguard), so the two are very close. In practical terms, my truck spends 3 months of the year in barley dust that somehow manages to make it inside the cab of the truck, even when the windows are closed. In other words, its super fine crap that works its way into everything. I haven't had an issue with one of these filters, and actually I found that my turbo intake hose was cleaner than the stock paper element.<br><br>Rod
The Scotty Air II filter system is unbeatable, Nothing gets to the turbo without going through the filter first. The inlet hose attaches directly to the filter and it is a very tight seal.<br><br> The stock box is really iffy when it comes to maintaing a good seal, some guys do have success with them, but do you really want to chance it in a high dust area?<br><br> JMHO
Back in the Gulf war the our helicopters couldn't run in the high dust and sand conditions so the military had K&N make air filters for the choppers. That has got to say something about the quality this company produces. And they only cost about $70-$80. Thats a lot cheaper than some of the others. Mine works great!
EverydayDiesel
22
06-03-2010 12:10 AM
Wildhog
13
08-04-2008 08:07 PM
nfsommer
04-16-2007 09:21 PM
Diesel Dave
07-09-2003 06:54 AM
