Air Filter
Air Filter
I already have a K&N in my stock airbox, but am thinking about a complete intake and filter setup, a big one. Will I notice much difference over the K&N or do I just let it be. Any personell experience appriciated. Thank You
I forgot to add. I got pulled over on Christmas eve night because my "pipes are too loud" What a bucnch of crap. He told me that I have to get something done or we will be seeing each other again.
A "cold air" intake such as a BHAF or AFE will wake up the turbocharger, not to mention the increased noise, but you probably won't hear it over your pipes!!! Most of them claim a 15 HP increase over "stock" Get one and you won't be disappointed, I know I wasn't!!! If you want more turbo noise toss the silencer ring, it's right in the inlet side of the turbo held in with a snap ring. I too ran the K&N in the stock box, this set-up is way better!!!
Tom
2001.5 2500 4X4 5-Speed Laramie SLT LB Quad Black. DD TTPM, DD Stage-1's, AFE, Bully-Dog 4" Pipe, JAKE Brake, Geno's Banjo's, Silencer ring MIA, 3 Autometer's on the A-Pillar, 2nd(and last) lift pump, Redline oil throughout. Catcher ECM soon!
Tom
Top's Younger Twin
I am partial to the Scotty Air Intake...lowers harmful exhaust gas temps better then any other intake on the market.
You will find it at my website. I stepped outside the box when I designed this intake. Its round.
Scotty
Scotty
anything is better than the K&N...
From what Ive seen the only options are a Scotty 2, BHAF, or a complete AFE intake (stage 1 or 2) with the proguard 7 filter.
http://www.scottyairsystems.com/
http://www.napaonline.com/cgi-bin/nc...6&prmenbr=5806
http://www.totallycustomtruck.com/ca...roducts_id/135
Scotty
Scotty
smokin_dodge5_9,
We sell ONLY the AFE Pro Guard 7 intakes and filter systems as they are a superior diesel filter to tstop the dirt the four layer gauze filters let thru. Here are some independent test reports on the filter systems.
This one is from a customer of ours that woudln't use any filter till they did the test and found out which one worked for flow and stopping dirt:
Here's what Dan Montegari of Precision Diesel Services says about advanced FLOW engineering's Pro-GUARD 7 filter media:
HIGH FLOW AIR INTAKE SYSTEMS
WHO IS THE BEST & WHY!
We received many letters asking which high flow air intake system to use. We decided to test a number of manufacturers’ systems to determine which system was superior. We tested each system and found systems manufactured by AFE (Advanced Flow Engineering) were the best by far.
Diesel engines use seven times more air than gasoline engines of equivalent size so clean cool air is a must for extended engine life, better fuel economy and additional power. A higher flow of intake air coupled with a high flow exhaust system allows for more power, a better fuel economy, extended engine life and reduced exhaust temperatures. On the other hand ingested dirt through the air intake system becomes Silicon in the engine oil, which is a harsh cutting agent and can damage your engine quickly.
We tested three very popular systems. I will not mention the names of the other systems as a courtesy but I will explain what problems we found with them. We evaluated the systems by a number of criteria, filtration protection, flow, and design, easy of installation and cost. Almost in the beginning of the tests we realized in most instances a new intake system was necessary to achieve our goals. We needed a kit that used mostly outside air and not hot engine compartment air. We decided to use systems designed to use mostly outside air.
Two manufacturers claimed their systems delivered cleaner air at a higher flow but this was far from the truth. We did not believe any of the manufacturers’ claims and tested each system by operating the vehicle 3,000 miles and performing an engine oil analysis to determine Silicon levels in the engine oil. The vehicle we used has an engine oil analysis performed at every oil change so we had a Silicon number of three (3) to base our tests on.
The first manufacturer’s system was fairly easy to install but we had problems with the oil used to coat the filter also coated the Mass Air Flow Sensor causing a service engine lamp to come on. I called the manufacturer but they had no explanation as to why this should happen but they had this complaint before. Through the three thousand mile test I had to clean the sensor three times to stop the service engine lamp from coming on. When the oil analysis results came back, it was discouraging with Silicon levels at eleven (11). I almost could not believe the result so we changed the oil and filter and repeated the test. The results were almost the same eliminating this manufacturer quickly. I contacted the manufacturer to discuss the results and they were not helpful and basically said, “what you see is what you get”!
We installed the second manufacturer’s system again changing the engine oil and operating the vehicle for three thousand miles. The first problem we encountered was the service engine lamp coming on and I thought the oil they used was coating the sensor again. I removed the sensor and found some oil on it which I cleaned off and reinstalled the sensor. Within ten miles the lamp was on again. I removed the sensor but there was no coating of oil on it. I then placed our scan tool on the engine and quickly discovered the airflow rate was too high for the sensor. I then realized the manufacturer had moved the position of the sensor into a higher airflow and velocity position trying to squeak a little more power from their system. I continued the test having to deal with the service engine lamp throughout the test period. The engine oil analysis gave a Silicon reading of eight (8 and along with the engine lamp problem did not give the manufacturer high mark but I felt if I discussed the problems with them maybe we could overcome them. I placed four calls to the manufacturer and I am still waiting for a call back! This surely eliminated this manufacturer.
The third manufacturer we tested was AFE (Advanced Flow Engineering). We used their Magnum Force air intake system. We operated the vehicle for 3000 miles and when the oil analysis came back it was promising with a Silicon reading of five (5). While five was the best Silicon result we had, it was not good enough. I called AFE and was pleasantly surprised when I discovered they were truly concerned. I spoke with a Mr. Paul Hardley who suggested I try their Pro-Guard 7 media they were about to release. He explained the new Pro-Guard 7 media was five layers of progressively finer mesh medical grade cotton gauze with micro fibers that attract smaller and smaller particles as air passes through. Combined with the five layers of medical [gauze] media, there are two layers of non-woven synthetic polyester fabric with random porosity. The filter media is sandwiched between two layers of aluminum wire mesh. He agreed to send two Pro-Guard 7 filters for a new test. I installed the Pro-Guard 7 filter, changed the engine oil and operated the vehicle for three thousand miles. The engine oil analysis was excellent with a Silicon reading of below three (3). Finally we found an air intake system that gave us a higher flow rate and better filtration. The AFE Magnum Force air intake system is a well designed system, easily installed and uses about 90% outside air. The filter is cleanable and the oil used to coat the filter is patented because it is formulated not to affect the airflow sensor.
Another positive factor of the high flow system was the fuel economy increased about ½ MPG in mixed driving and 1 MPG during highway tests. The filter media used by AFE will not collapse if it gets wet or subject to high boost pressures. They also offer pre-filters for most of their applications for very dusty or dirty operating conditions. We carry a full line of AFE products with Pro-GUARD 7 media. If you order an AFE system from another source, make sure it has a Pro-GUARD 7 media.
A very important factor in this test was the manufacturer was willing to discuss problems with their products and help to overcome them. My hat is off to Paul Hardley and all the people at AFE!
Dan Montegari
President
This one was done on a Duramax forum and was done by TESTAND Corp of RI, they are a filter test facility that does testing for a living:
SPICER Posted: 16 July 2004 at 3:47pm | IP Logged | Report Post
Diesel Addict
Group: Diesel Addict
Posts: 302 The following is the complete test results. In order of rank from BEST performance to WORST in the categories of FILTERING EFFICIENCY, FLOW RESTRICTION, DIRT HOLDING CAPACITY and TOTAL DIRT PASSING THE FILTER DURING TEST.
SPICER wrote:
In the order of filtering efficiency the results are:
FILTER % Efficiency
AC Delco OE 99.93%
Baldwin 99.72%
No name filter (made for gas engine, 1/3 less pleats) 99.32%
AFE ProGuard 7 (73-10062), panel filter 99.23%
WIX/Napa 99.03%
Purolator 98.73%
Amsoil, new style 98.63%
UNI 97.93%
K&N 96.80%
Additionally, these 2 were tested using FINE test dust. The K&N was cleaned and retested, the AFE was the conical version:
K&N 89.85%
AFE Conical 92.33%
FLOW RESTRICTION FROM BEST TO WORST:
FILTER RESTRICTION in Inches H2O
K&N 4.54
Mystery bargain filter 4.78
AFE Pro Guard 7 Panel 4.99
Purolator 5.05
WIX/Napa 5.06
UNI 5.40
Baldwin 5.71
Amsoil 5.88
AC Delco 6.23
DIRT HOLDING CAPACITY From best to worst. This is the AMOUNT OF DIRT it took to create an ADDITIONAL 10 inches of water restriction. At that point the test is terminated.This indicates HOW LONG a filter is good before it must be cleaned or replaced.
AC Delco 573.898 grams
WIX/Napa 447.366
Purolator 388.659
Baldwin 388.154
UNI 374.638
Mystery bargain 350.402
AFE Pro Guard 7 232.516
K&N 211.58
Amsoil 196.323
TOTAL DIRT PASSING THE FILTER DURING THE TEST. This is how much dirt your engine will take in if you use the filter for the duration that would cause the filter to become "dirty" enough to need replacement or cleaning. The "Dirt Passing The Filter" is the dirt collected by the "Post Filter" during the test.
FILTER DIRT IN GRAMS PASSED
AC Delco 0.4 g
Baldwin 1.1g
AFE Pro Guard 7 1.8g
Mystery Bargain 2.4g
Amsoil 2.7g
WIX/Napa 4.4g
Purolator 5.0g
K&N 6.0g
UNI 7.9g
Note: The Purolator was reported to have a seal malfunction during the test and passed more dirt than it would have with a good seal.
Interesting. SPICER
__________________
"03 2500 HD, Kennedy Mega Filter, STOCK PAPER AIR FILTER, Oilguard Bypass, Primrose, Baldwin Oil Filter, ARE Camper Shell, Line X Liner, Westin Nerf Bars.
User Is Offline
If you have any questions just give us a call.
Mark @ DPPI
Dan Montegari
President
Diesel Addict
FILTER % Efficiency
AC Delco OE 99.93%
Baldwin 99.72%
WIX/Napa 99.03%
Purolator 98.73%
UNI 97.93%
K&N 96.80%
K&N 89.85%
AFE Conical 92.33%
K&N 4.54
Purolator 5.05
WIX/Napa 5.06
UNI 5.40
Baldwin 5.71
Amsoil 5.88
AC Delco 6.23
WIX/Napa 447.366
Purolator 388.659
Baldwin 388.154
UNI 374.638
K&N 211.58
Amsoil 196.323
AC Delco 0.4 g
Baldwin 1.1g
Amsoil 2.7g
WIX/Napa 4.4g
Purolator 5.0g
K&N 6.0g
UNI 7.9g
Interesting. SPICER
__________________
User Is Offline
Mark @ DPPI
I don't mean to keep asking the same question, but I am SOOOOO confused. In this thread, Supermod56 and Dr Evil both refer to a BHAF and an AFE. I first thought AFE, K&N, Scotty's, etc were all BHAF's, but now I am not sure.
Please explain to a thick headed country boy, that only knows about gas and alcohol engines.
I am spending about 5 grand on my truck now and I want to spend it wisely.
Thanks
Thanks
Technically, yes, they are all BHAF's.
Scotty is it's own system, so we just call it the Scotty, same with the AFE.
Most of the time, the term BHAF referres to the big round paper filters,
such as the Fleetguard AH19037 that I have.
phox
phox
Yeah Phox is right...
The Scotty can be seen here: http://www.scottyairsystems.com/
The AFE (Stage 2): http://www.totallycustomtruck.com/ca...roducts_id/135
These are more correctly called Intake systems, whereas an actual BHAF (Big Honkin Air Filter) is just a generic (big) air filter used on industrial diesels and maybe some tractors. They look like this:
and https://www.dieseltruckresource.com/...cat/500/page/2
and
https://www.dieseltruckresource.com/...cat/500/page/1
The BHAF is the cheapest route and offers middle of the road perfromance compared to the Scotty 2 and AFE Stage 2.
Hope that helps clear things up a bit.
and
After reading that report I am a little alarmed that the Scotty II I bought two months ago came with a uni filter when it looks like the previuos Pro gaurd-7 filter was better, or was I wrong in saying that the scotty used to come with a progaurd 7, I am positive it was at least a AFE. Scotty is probably on the prowl here somewhere and I remember him saying he had good Silicone levels in his tests, It would be good to hear his 2 cents.
The last test where the amount of pasted dirt where the uni placed LAST is a scary thing I guess I'll be ordering up a oil analysis when the dust picks up
as long as he doesn't chime in on my head for bringing this up. after seeing the concrete ball he lifts for "fun" i might add, in reddeer, add I am a little scared.
Scotty ....... be gentle I am just enquiring
If I remember correctly, the Progaurd 7 didn't come in a size compatable with the Scotty housings,
and in talking with AFE, it wouldn't be cost effective to have them make one that would fit.
The Uni's he's currently using are better then the AFE's he used to use.
(otherwise, why would he have switched?)
phox
phox
