aftermarket hub/bearing?
basically my bearing is worn out in the front drivers side and i have to replace the whole hub to replace the bearing. is there anything aftermarket out there for it?
my books say up to 99 but i dunno if its the same for 2000/01 cause there was some suspension/steering changes in 2000 on the front axle.
thanks again
thanks again
Try here;
http://www.quad4x4.com./index.html
I haven't used them yet, but will be giving them a shot probably in the next week.
Before you purchase make sure you check with the Dodge part counter. I got a price cheaper by far than the NAPA price for my '99. Also make sure you get the right ABS setup, if you use a 2 wheel on a 4 wheel it will not work and visa versa.
Originally posted by smokindog
Try here;
Try here;
i phoned about that front hub assembly that they have and all it is is an oem part that they offer. its not aftermarket. just clearing that up for some guys if you thought otherwise.
DiEseLjunKy
32
12-27-2007 07:37 AM
Crimedog
02-27-2007 10:39 PM
