Aftermarket harmonic ballancer or oem??
I tore my truck apart this weekend to perform the infamous dowel pin mod. Front seal had leaked onto balancer, causing the rubber the swell. I'm not planning anything really serious, use this truck for towing horses, going to keep it in the 650ft lbs/350+/- hp range. Just buy the cummins balancer or is there one that's better/ or even cheaper! looking for reliability..
How much is the stock damper? I run fluid dampers on both of my trucks, its worth the money IMO, although I've never run one on something that doesn't have a dual disc. They are about $450. All depends on what the stocker is worth.
SKATERHAULER
10-02-2013 07:34 AM
wvopowered
02-10-2010 11:42 AM
BAJA MAN
11-21-2006 06:49 PM
coalburner400
04-10-2006 08:57 PM
