After much thought...........
Old 01-05-2006 | 02:32 AM
runamuk's Avatar
MadDog01,
My offer extends to you also!!
Everyone knows that the Blah,blah,blah stops at the track!
Still waiting.........................LOL!
Any takers??
Rick
Old 01-05-2006 | 07:57 AM
Ph4tty's Avatar
Originally Posted by Dieselcamper
On the two settings that say
"soft Catcher" and "mild catcher" are they reduced timing , fueling
or both.
From what I understand there are a series of fuel maps that can be used with the stock timing or with the catcher timing. The maps range from below stock fueling to catcher fueling and each map is slightly more aggressive than the last. But you can't get a smarty cuz ya got to wait until I get mine =P
Old 01-05-2006 | 12:48 PM
Dieselcamper's Avatar
Runamuck, I'll try and make the dragstrip meeting,but no can do
on the racing. Clutch started slipping in 6th gear three weeks ago.
Now this week it's slipping in 5th and 6th gear if I get on the throttle
too much
Old 01-05-2006 | 01:17 PM
runamuk's Avatar
Let's see what can you do with your last $700.00 hmmmm.
Sorry to hear about your clutch!
Pm CASMOKIN as he just put a clutch in his rig maybe he can give you a few ideas.
Hope you can make it anyway!
Rick
Old 01-05-2006 | 01:20 PM
chinook country's Avatar
Hey dieselcamper, what's the problem with your current set-up? I thought the VA and the 275's would be an ideal combo for towing. Maybe spend the dough on a new clutch...
Old 01-05-2006 | 02:23 PM
pmtg's Avatar
After thinking everything over and realing thinking about why I originally
bought this truck for (Camping Trailer) I realized I was rapidly approaching
mods that would ultimately make my truck less effective at towing, such
as fueling boxes and big injectors. I still have the $700.00 to spend and I can do one of two options. What would make the best towing/power combo.
#1 Take out my RV275's and replace with Mach 1.6's
These would go along with my Van Aaken V5
or
#2 Take out the Van Aaken and replace with the Smarty
This would go along with the RV275 injectors
Please no "do both" I can't aford it
too much
how come you asked us how to spend your $700 to help you make more power when you clutch started slipping 3 weeks ago?
Old 01-05-2006 | 02:30 PM
Well I was hoping the clutch would last till late Feb/early March. Thats
when the tax refund was going to buy a new clutch.It's probably in my
best intrest to buy the clutch now and use the tax refund for more
power later. It's just more fun to add power than replacing a slipping clutch
Old 01-05-2006 | 03:32 PM
CTD NUT's Avatar
HEHE......that sounds like a more appropriate plan! If you think your clutch slips now, wait till the Smarty or 1.6's are in. You wouldn't be able to use any of that additional power if your clutch is already slipping now. FWIW, the 1.6's will add a noticable amount of additional power for towing over the Smarty. The Smarty is good for about 60 hp but the throttle response and drivability are where it really shines......for the largest gain in towing power, 1.6's will be best......combine the sticks with the Smarty and......well, you already know where we are going with that!
Old 01-05-2006 | 03:56 PM
cumminsdriver635's Avatar
too much
You have answered your own question. Buy the clutch. Its more fun to at least be able to use what you have.
Eric
Old 01-05-2006 | 04:03 PM
HOHN's Avatar
Let me tell you what a Catcher and M4s can do to a stock clutch
Anyway, I'd go for the smarty. You can always go with bigger injectors later.
With the "half power" feature of the Smarty, you could probably tow with M6s.
Probably.--jh
Old 01-05-2006 | 06:10 PM
TORQUE's Avatar
For towing I wouldn't go bigger than Mach1.6's, with bigger injectors you can run into egt problems, and have no way to reduce power output from them(except right foot-or timing box will help somewhat) .
Mach 1.6's were designed to tow with, while keeping temps in check, and keeping mileage same or better, and have excellent towing power. Towing even up looooong hills, I top out usually at 1200-1250f pre-turbo, floored up the hill in o.d.. See my sig.
Old 01-05-2006 | 10:42 PM
BigBlue's Avatar
Probably.--jh
So you finally destroyed your clutch? I'm surprised it lasted this long.
Old 01-06-2006 | 08:13 AM
Ph4tty's Avatar
You guys running a contest? From what I've read, I'd put my money on Hohn's clutch before your tranny =P
Old 01-06-2006 | 08:19 AM
Ph4tty's Avatar
Please no "do both" I can't afford it
Both options are spending money twice on stuff you have. Save your money. You can do your taxes early then spend on stuff like fuel system upgrades and a clutch.
Old 01-06-2006 | 12:21 PM
HOHN's Avatar
Actually, it's still holding on, for the most part. I can get to 35psi with it still.
But the bottom end of the Catcher and the fueling of the M4s will eventually Catch(er) up with me.
But I *can* tell that it's getting soft. Engagement isn't crisp, it's mushy. It used to snap you forward when you dumped the clutch in 1st. Now it just kinda eases into gear just in time to have to shift.
The plan is for a new CON FE sometime this summer, complete with the MEGA pilot bearing from quad4x4. This pilot bearing is freaking unreal, and I'll NEVER have to open up my trans again!! Pic of bearing, which is far right compared to stocker on far left:
I'm trying to follow the "do it once, do it right" method.-jh
RyeThomas
18
04-18-2007 03:38 PM
pet05
07-05-2006 01:04 PM
matador
19
05-14-2004 03:57 PM
danimal 95
03-20-2004 10:00 AM
